New parts added 1967-1972 F100/F250 parts galour!!!
Cleaning out my garage and have some good healthy 1967-1972 Ford truck AZ parts.
1969 grill $150 good shape, one dent, straight
Heavy duty 2" hitch $110
Painted Radiator support $60
Heavy duty bumper $100
Aux fuel tank skid plate $40
1972 F100 complete, Shortbed trim very straight,minimum dings,black is faded. $80
A/C blower unit $60
Ranger emblems $15 each
70-72 F.O.R.D emblems $20
Hood side emblem $20
Taillight bezels ok set $10
F250 Hub caps set $30
72 grill insert $30
Sport custom emblem $25
C6 transmission pan $20, needs cleaned
Older ford A/C compressor $30
I can send pictures.
A/C blower unit $60
72 grill insert $30
Re: 1967-1972 F100/F250 parts galour!!!
Interested in the '69 grille - can you post pics? Thanks.
Interested in the radiator support, will it fit a 69 ranger with a 390? also will you ship to NY? id like a pic or two if possible.
Thanks!
Mike
Thanks!
Mike
Pm sent
What do the F250 hub caps look like? Can you post a picture please?
Mine is bent.
Mine is bent.
Pictures can be seen here http://phoenix.craigslist.org/nph/pts/4540607995.html
Grill to hood latch body $50
A/C blower unit $60
Battery tray $25
Tail gate supports set $40
Tail gate handle $50
Tailgate side supports hinge $20
70-72 turn signal support set $40
Rear LH reflector $10
One f250, Hood side emblem $20
Taillight bezels dents set $5
72 grill insert $30
2x Factory 390 crank pulley $40
2x Factory 390 water pump pulley $20
Factory Ford power steering pulley $30
A/C blower unit $60
Battery tray $25
72 grill insert $30
http://phoenix.craigslist.org/nph/pts/4540607995.htmlDevin Ezersky wrote:What do the F250 hub caps look like? Can you post a picture please?
Mine is bent.
Re: New parts added 1967-1972 F100/F250 parts galour!!!
Hi
I am interested in the aux tank skid plate.
What does it include , hardware, brackets
thanks
thanks
Thanks for the hood letters JP
![Image](https://imagizer.imageshack.us/v2/735x413q90/855/4c49.jpg)
They look good! And your welcomeelsilerjr wrote:Thanks for the hood letters JP
[ Image ]
I have the brackets but I would buy new hardware.BLS2042 wrote:Hi
thanks
Still interested?Devin Ezersky wrote:What do the F250 hub caps look like? Can you post a picture please?
Mine is bent.
Do you still have the AC blower and compressor available still? Also do you know if they're in working order? Thanks. Nate
Pm sentnatec96 wrote:Do you still have the AC blower and compressor available still? Also do you know if they're in working order? Thanks. Nate
Hey guys still have tons of parts available.let me know
Pictures can be seen here.
http://phoenix.craigslist.org/nph/pts/4606727112.html
1969 grill good shape, one dent, straight sold
Grill to hood latch body $40
Heavy duty radiator $20 needs fixed
Tail gate handle $40
70-72 turn signal support set $30
Ranger emblem $15
72 grill insert $30
Older style Ford Ac compressor $30
Factory 360/390 Ford cam $40
390 truck oil pan, needs drain plug fixed $5
2 sets of door step plates $30 each set
1 set of wheel we'll trim $30
3 Rim caps $20
360-390 intake set $25
Door steps $30
Window washer reservoir $20
Ranger emblem $15
72 grill insert $30
3 Rim caps $20
Door steps $30
