Good evening,
I've got a 1969 f100,3 speed,manual transmission,straight 6.
I've looked thru the forums but can't seem to nail down a definitive answer for tranny fluid or diff fluid. Any help would be great!
Thank you!
Tranny fluid help needed
- BobbyFord
Re: Tranny fluid help needed
75W-90 should suffice.
Thank you BobbyFord!
Would that suffice for the differential as well? Also,synthetic? A particular brand that would be better than others? Lucas or something similar?
Thanks again
Thanks again
- BobbyFord
I run 90W-140 in my diff.
Some guys do not like the way synthetic oil shifts in the older transmissions. I think it's preference.
- hillcountryflt
BobbyFord Are you going to pull the covers on your differential to drain it?
I have not found the drain hole and was planning on just pulling the cover and clean it out real well while I am there.
Draining the tranny was OK. Filling it was a bit more challenging.
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
2016 Explorer;
2020 F150
