I can shift through all of my gears, However the actual shifter is loose ( there is excessive play in the stick ) it swings from side to side and if it is not in the correct place it will not go into 4th gear ( I'm assuming because the stick isn't lining up ) but i have no clue how to identify what transmission is in the truck
im not sure if i just nee to tighten things up or is something broke where the stick goes into the transmission, any help would be awesome !!
![Help :help:](./images/smilies/icon_help.gif)
