67 f100 2wd to 4wd swap questions.
67_F100
Post by 67_F100 »
I heard that the difference between the 67-72 frames and the 73-79 frames is that the 73-79's are wider in the rear...but they are the same up front.
So my question is, Could I put the bumpside cab and frontend on a dentside frame and then put a flatbed on her?
Song references a bump if you listen to when the truck is bought.
http://www.youtube.com/watch?v=0leWmtd6Fww
fordguy_78
Re: 67 f100 2wd to 4wd swap questions.
Post by fordguy_78 »
Search..... or read the some of the 4 or 5 same questions on the first page
Phill
78 Mustang
67 F250ish
2010 F250 Harley Davidson
67_F100
Post by 67_F100 »
i did and figured out what I need just keeping this open for anyone to tell me its not going to work.
robwymer
Post by robwymer »
67,
Fordguy has a point. Read the chassis comparison write-up in the tech articles. It will tell you what you need to know.
Hint: If installing a bump cab on a dent frame is a bolt-on affair, it serves to reason that the opposite would be true too, though I don't know why anyone would want to...unless they intended to re-sell the "Frankenstein" dent as a real dent??? But of course, that would be unethical and probably illegal if the purchaser were uninformed.
Rob
67 F-100 Flareside, 300, Offenhauser 360, Holley 390, Duraspark and MSD ignition, NP-435 4-speed, 3.55 Dana 60, and it will absolutely roast 30" rear tires taking off in 2nd (the one time I tried scared the Bejeezus out of me)
Next engine mod: RV cam (252*)
"They just don't make 'em like they used to."
robwymer
Post by robwymer »
[quote="fordguy_78"]Search..... or read the some of the 4 or 5 same questions on the first page[/quote]
Too bad nobody's doing much answering on those 4 or 5 other posts. Must be a stumper. :hmm:
67_F100
Post by 67_F100 »
Ok so just to clear up what I read.( need more confirmation) if I take a 73-79 4x4 frame and put my 67 front end and cab on it and then install a flatbed there should be no wheelbase issues.
fordguy_78
well no why would there be
Phill
78 Mustang
67 F250ish
67_F100
Post by 67_F100 »
I dont know, but im not the most experienced with these kind of swaps so I wanted to make sure.
fordguy_78
Yeah the front body mount locations will let you put a cab off of any thing from 67-2010 also probably 66 and earlier and 2011 on. now the rear cab mounts change depending on cab stile and wheel base so those have to be custom.
here a 67 siting on an 88 bronco frame.
Phill
78 Mustang
67 F250ish
robwymer
Post by robwymer »
Fordguy,
I had no idea a Bumpside cab could be mounted on so many different frames.
Did you install leafs on the front of that 1988 Bronco frame?
Rob
fordguy_78
yes I did 78/79 dana 44 and now its go my own radius arms and 85-91 dana 60 with coilovers.
Phill
78 Mustang
67 F250ish
