![Image](http://i1024.photobucket.com/albums/y302/botoflucket/Snapbucket/6330DBD5-orig.jpg)
Due to the fact that I had to trim the bottom flange of the frame, I have to section the spring hangers so they don't run into the tank. (And no, I am not the one responsible for the bed mounting mod' on the upper flange.) BobbyFord wrote up his fuel tank swap and it was excellent. I am changing it up a little bit to meet my needs. I am going to mount the tank to the bottom flange of the frame with J-nuts and bolts from the bottom.
![Image](http://i1024.photobucket.com/albums/y302/botoflucket/Snapbucket/images.jpg)
I drilled the cross member ahead of the fuel tank so I can bolt directly to it.
![Image](http://i1024.photobucket.com/albums/y302/botoflucket/Snapbucket/37307CBD-orig.jpg)
I will fab up some tabs for the rear and weld them to the rear cross member, then bolt to them in the same manner.
![Image](http://i1024.photobucket.com/albums/y302/botoflucket/Snapbucket/B940C8C9-orig.jpg)
I'm pretty happy with how its coming along. I think I may even have enough room to run a 90* bend and a filler in the bedside.
![Image](http://i1024.photobucket.com/albums/y302/botoflucket/Snapbucket/1CB15CA3-orig.jpg)
