How do I remove and replace the automatic transmission indicator assembly on a 1979 tilt steering column? All I can find is exploded diagrams.
Anyone have a cheap source for replacements?
Tilt column transmission indicator
- 1970 Sport Custom long bed, 360 C6 2WD -
- Mancar1
Re: Tilt column transmission indicator
I believe LMC and Dennis Carpenter has them. Pull the steering wheel to do the replacement. I replaced one in my 79 Ford 1/2 ton, but that was back in 94. (that doesn't sound right, back in 94
) You will get it done
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
