parting out 67-72 2wd trucks (new list of parts) 12/10/11
Private parties only. No eBay/Craigslist listings.
Ranchero50
Re: parting out 67-72 2wd trucks (new list of parts) 12/10/11
Post by Ranchero50 »
Your wish... Expect some spam, web crawlers love email addresses in forums. That's why we ask you to use the PM or Email icon.
dirtyred
Post by dirtyred »
Do you have a fan shroud for a 71 302?
kevins72
Post by kevins72 »
hello, do you still have parts, im looking a drive shaft yolk that can hook up to a c6 trans? if you do i can send measurments later. also do you have any rust free long beds left? prices? thanks for your time, kevin
BrotherMabe
Post by BrotherMabe »
rmurphy wrote:
Preecha wrote:I have a 1968 F100 Ranger
I need a grill
And power steering components
And power brake components
And any advice would be helpful
don't have a good grill, have p/s box, pump, hoses and brackets for 360. What brake parts do u need? I can send pict of what I have pm me your email. Thanks
Do you still have pump, hoses and brackets for 360?
Its been a while, I know...
I hope you do.
rmurphy
Post by rmurphy »
know I have the p/s brackets, may have a pump and hoses. just parted out a 360. need any other stuff. water pump pulley or a/c brackets? look up my add for the 360 brackets on for sale items.
460 crew
Post by 460 crew »
Do you have a clutch pedal available?
tac
Post by tac »
I need complete 6 cyl throttle linkage from pedal to carb and also need 6 cyl exhaust bracket that bolts to back of bell housing.
BrotherMabe
rmurphy wrote:know I have the p/s brackets, may have a pump and hoses. just parted out a 360. need any other stuff. water pump pulley or a/c brackets? look up my add for the 360 brackets on for sale items.
Yes.
I need all pulleys.
Coolers, if you have them.
Pump hoses.
All for a 1968 F100 Ranger, 360 converted to 390.
I am very new to this.
So just to let you know, I am upgrading a manual steering to p/s for a column shift 3-speed. I did find a Bendix box.
I also would like to upgrade standard drum to power drum. And I have a dual reservoir.
Brackets for boosters.
Any advice is helpful.
Any way that I can call you?
I am in NC.
My cell # is 336-847-2955
rmurphy
Post by rmurphy »
460 crew wrote:Do you have a clutch pedal available?
yea got clutch parts. pedal assy, frame mount, motor ball mount, bar assy, and rod. need to know what motor u have. rods are st or curved.
rmurphy
Post by rmurphy »
Yes.
I need all pulleys.
Pump hoses.
I am in NC.
I'll PM you.
rmurphy
Post by rmurphy »
tac wrote:I need complete 6 cyl throttle linkage from pedal to carb and also need 6 cyl exhaust bracket that bolts to back of bell housing.
I need to see if I have a extra assy. I'am installing a 6cly in a truck now. get back to you.
460 crew
Post by 460 crew »
I just need the pedal arm and the bolt that goes through. I deleted just that part a while back when I went auto and now I,m switching back manual and running a hydro setup, dunno what I did with my pedal.
rmurphy
Post by rmurphy »
yea I got a 69 I'll pull out and can send you $15 and shipping.
rmurphy
Post by rmurphy »
kevins72 wrote:hello, do you still have parts, im looking a drive shaft yolk that can hook up to a c6 trans? if you do i can send measurments later. also do you have any rust free long beds left? prices? thanks for your time, kevin
I've got one out of a 70 with a 360 auto. It is bolted up at the output shaft type. Has a 4 bolt flange. I have the whole shaft if you need. for a long wheel base truck. don't think I have the slip in type yolk. You can find them anywhere.
wblcrz
Post by wblcrz »
do you still have the 8 ft bed and if so how much?
