Math help
- 72hiboy4x4
- 19674x4
me no hablo espanol, hola senor, como esta,muy bien, tengo uno pregunta, Que hora es? ah si si es la una,
OH MY GOD I AM GOING MEXICAN
My Photo Album
- HOWDY69
- mrung0wa
No No No 19674x4!
It's Spanish, not Mexican! I did not detect any slang from that conversation.
Yes fordman that is correct!
Ya see I got 6 grades of education in my brain.
I don't know if I'm gonna be an astronaut or a double not secret spy.
Lawrence
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
- 19674x4
My Photo Album
- HOWDY69
You folks seem to be enjoying math so much here is a quote from the FordFE site.
ENJOY
Any tube will flow a wide range of cfm ratings, but the higher the cfm, the higher the pressure drop through the tube. The equation you need is called Poiseuille's Law:
Iv = (Pi*r^4/8nL)*deltaP ,
Where:
Iv = rate of flow in cubic meters per second
Pi = 3.1416
r^4 = radius of the tube in meters, raised to the fourth power
n = the viscous flow constant for the material in question
L = length of the tube in meters
deltaP = the pressure drop in Pascals
All this metric stuff is confusing, so here are some conversion factors (from www.onlineconversion.com):
1 psi = 6894 Pascals; 1 Pascal = .000145 psi
1 cfm = .0004719 cubic meters per second; 1 cubic meter per second = 2119 cfm
1 foot = .305 meters; 1 meter = 3.279 feet
1 inch = .0254 meters; 1 meter = 39.34 inches
Also, the viscous flow constant (n) for air at 20 degrees Celsius (68 Fahrenheit) is 0.018 Pascal-seconds.
So, let's say you want to duct air from the inboard headlight of your 64 Tbolt to one of the Holley carbs on your 2X4 FE induction system. You want to use a 5" diameter tube, 4 feet long, and you want to limit your pressure drop in the tube to 0.25 psi. How much air will the tube flow at that pressure drop?
- The tube radius is 2.5 inches, or 0.0635 meters.
- The tube length is 4 feet, or 1.22 meters
- The pressure drop is .25 psi, or 1723.5 Pascals
So, the flow rate (Iv) is ((3.1416*.0635*.0635*.0635*.0635)/(8*.018*1.22))*1723.5,
which calculates out to 0.501 cubic meters per second, or 1062 cfm. So, you can flow up to 1062 cfm through that tube, and maintain a pressure drop of 0.25 psi or less.
Ain’t physics wonderful?
LOL – Jay
ENJOY
Where:
Pi = 3.1416
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
- 19674x4
ya lost me at Poiseuille's Law
i suck at math
i suck at math
My Photo Album
- wildcard
- mrung0wa
re: Math help
Hey when are we goin' to get back to the Beverly Hillbilly stuff?
That was a heap-O-fun!
Yall come back now, yahere!
Lawrence
Lawrence
- 1968flareside
re: Math help
1968 F-100 Flareside
1999 F-150 XLT 4X4
http://www.fordification.com/galleries/ ... ?cat=10023
and
DON'T FORGET!!
1999 F-150 XLT 4X4
- binder56jd
re: Math help
what would be wrong with using a level and a angle indicator? saves a lot of migraines
jd
now serving #235
now serving #235
