Short bed CrownVic swap
SecondCamperSpecial
Post by SecondCamperSpecial »
A good friend of mine just drove 800 miles round trip to pick up a couple of project trucks.Got a clean short bed and a long bed parts truck. I am going to do a 03 Crown Vic front end and engine swap. Pictures to come.
1968 F250 Camper Special 390
1964 Galaxie hardtop 352
1967 Cougar project
1993 F350 Crew cab 5.8
1988 Bronco 5.8 C6
1966 Mustang fast back project
New 1962 Falcon Gasser project
SecondCamperSpecial
Re: Short bed CrownVic swap
And it begins!!!!
1967 Cougar project
1988 Bronco 5.8 C6
angryfordrabbit
Post by angryfordrabbit »
looks good. about to start mine as well. stripped the crown vic this last week.
SecondCamperSpecial
More workImage
1967 Cougar project
1988 Bronco 5.8 C6
elgemcdlf
Post by elgemcdlf »
:pop:
wbulick76
Post by wbulick76 »
So far, so good! Just picked up my CV front end last week. Getting ready to tear into mine too.
1968 F100 SWB project----CV Front----4.6 automatic
SecondCamperSpecial
Stage one complete
1967 Cougar project
1988 Bronco 5.8 C6
tylerb43
Post by tylerb43 »
You're using the engine from the CV as well?? Details please! Trans/trans controller? Stock diet or aftermarket EFI? Leaving the stock rear? (you knew these questions were coming) :lol:
SecondCamperSpecial
Plan is to use most of the P71 drivetrain. Buddy wants ABS :eek: This is going to be daily driver so will be stock engine trans as of now. Planning on dropping rear of truck 2 to 4 inches. It is still going to be used so he dont want it slammed. Has anyone used the CV rear axle? Why does everyone use Explorer? Fabbing spring mounts will be no problem. Have Factory A/C off a parts truck to install. I think biggest problem will be speedometer. Not sure if there is an extension housing to use gear drive? This is a learning experience. Learn a little at a time. Building one for my self next year. :D
1967 Cougar project
1988 Bronco 5.8 C6
tylerb43
Post by tylerb43 »
Guys usually go with the Explorer rear because the right axle code will get you 3.73 LSD. And - it's track width is much narrower than the '03 & up P71. (59.75" vs. 65.5") But if you use the P71 rear, the backspacing on your wheels will at least be the same as you'll need for the front.
wbulick76
Post by wbulick76 »
Check with Dakota Digital for the stuff to hook up the speedo. They have a few options that may work.
SecondCamperSpecial
Some shots from yesterday.
This shows the transmission pan sitting on the second cross member. Had to remove engine and clearance it..
1967 Cougar project
1988 Bronco 5.8 C6
SecondCamperSpecial
fixed
Used stock transmission cross member with C6 transmission mount. We also used the center steering shaft and modified it with a grinder for it to work with a Borgenson joint. This is connected to a 1978 Tilt wheel column.
1967 Cougar project
1988 Bronco 5.8 C6
SecondCamperSpecial
1967 Cougar project
1988 Bronco 5.8 C6
angryfordrabbit
so you were able to adapt the c6 mount with the 4r70w trans. i fixing to start putting mine together in the next couple of weeks.
