Math help
- willowbilly3
Math help
OK some of you guys who remember the equation. I need to set the cross member in my hotrod at 7 degrees. If the crossmember is 3 inches wide then how much in inches off level should it be?
I think 3 inches would be the diameter so 3 squared times pi (29.76) divided by 360 (.0822) times 7=.5754
Did I do that right? Over 1/2 inch seems like a lot.
- HOWDY69
Ok 23 people have read this post and no one has volunteered so I guess I will jump in. I understand the cross member is supposed to be at 7 degrees. Is that really width wise or is it 7 degrees length wise?
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
- 68F250
re: Math help
Hey I just got home!
That's a trig function. See if I got the diagram right for what you are describing:
Barry
re: Math help
You would take 3" times pie (3.14) which would give you 9.42" and this would be your circumference. Then take 9.42" and divide it by 360 and you get .026", then take that times 7 and you get .183" or approximately 3/16".
When you took 3" and squared it and took it times pie you came up with the square inches of a 3" diameter circle rather than the circumference, and that is why you came up with such a high number.
Bob
Bob
- HOWDY69
- 19674x4
i agree with that, i found your mistake when you came up with square root of 3 times pi.
My Photo Album
- HOWDY69
I think Bmerkley58 needs to multiply his answer by 2 because 3 is the radius not the diameter. 2 times .183 is .366 which is about what you get using trig. The straight line from the trig calc will be a little shorter than the arc calculation using PI.
- 19674x4
HUH???????????????????
My Photo Album
- HOWDY69
Since one end of the cross member is held in one place while the other rotates 3 is the radius not the diameter
The circumference is 2 PI R = 2 x 3.14 x 3 =18.84
(18.84 / 360) x 7 = 0.3663 which is the arc of 7 degrees
The other method is more exact since you will probably not measure along the arc on the car but you have to know the sine of 7 degrees to do the calculation. It gives you the vertical line as shown by 68F250 0.3656.
It is shorter to walk in a straight line than around a circle.
Was that any better?
- mrung0wa
re: Math help
Wow!
I am impressed. I strongly believe that you Brothers should be on TV!
You guys know your sipherin' and gosinta's (you know 2 gosinta 8, 4 times).
I'm proud to be apart of this meeting of the minds!
Lawrence
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
- willowbilly3
re: Math help
Thanks guys. I never took trig so I don't know the sine and cosine stuff.
In case you are wondering the 7 degrees is for the kingpin inclination. Most old buggy sprung Fords (like model As) had the front crossmember set at that.
- mrung0wa
re: Math help
And I thought that I was through with my book learnin'!
Lawrence
- heep70
re: Math help
I agree with 68f250. I actually got 0.359999173"
7 tanget cosine x 3" = 2.97" x 12% = 0.359999173"
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- flyboy2610
re: Math help
I just read this thread.
Now my brain hurts!
Now my brain hurts!
Red Green
you'd better be right.
Red Green
