L or NL on axle ID page
Can someone tell me the meaning of the L or NL on the rear axle assembly ID page? This is probably something any moron should know, but I'm not just any moron.
Re: L or NL on axle ID page
Where is the L located? If it is in between the ratio numbers like 3L25 it is a limited slip unit
clint
clint
71 F100 SportCustom
460 C6. Disc Brake/Power-steering/automatic Swap. 3.00
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- FORDification
- Site & Forum Admin
L = Locking (limited slip differential)
NL = Non-Locking (open differential)
I was thinking that might be the case, but wasn't sure. Also, some of them have a 4, as in L4 or NL4. Mean 4 pinion gears?FORDification wrote:L = Locking (limited slip differential)
what about L4? i am trying to figure out whether or not my limited slip clutches are 4 or 5 tab without tearing it apart because if its a 4 tab the clutches and steels cost $105, but if it a 5 tab they are almost $250 so i dont want to tear into it and not have enough money and waste my time, also the parts guy i talked to said his book said the early model ford 9 in. are 4 tab and late models are 5 tab but gave know indication to where the line was drawn, anyway i know i have a 31 spline ford 9 in. and it is in a 79 bronco ranger XLT with a 400 and a factory trailer package thanks for reading and any help would be much appreciated
axle code on door H2
axle tag code
WFE-AY 9EB
3L50 0 624A
axle tag code
WFE-AY 9EB
3L50 0 624A
do some shopping around none of these are mine
http://www.ebay.com/itm/9-Ford-4-Tab-Tr ... 08&vxp=mtr
http://www.ebay.com/itm/8-9-Inch-Ford-T ... 5b&vxp=mtr
http://www.ebay.com/itm/Currie-Enterpri ... 29&vxp=mtr
http://www.ebay.com/bhp/ford-8-8-clutch
http://forums.vintage-mustang.com/vinta ... rence.html
