2wd should i lift or do a 4x4 swap?
67_F100
Post by 67_F100 »
i have a 2wd 1967 ford f100 ranger/ camper special with a 352 FE engine......i have heard this truck is rare......should i just lift it and put 35"tires on it or should i do a 4x4 swap.....allso for a 4x4 swap what would i need to swap and from what year truck to mine
thanks
Song references a bump if you listen to when the truck is bought.
http://www.youtube.com/watch?v=0leWmtd6Fww
HIO Silver
Re: 2wd should i lift or do a 4x4 swap?
Post by HIO Silver »
67_F100 wrote:i have a 2wd 1967 ford f100 ranger/ camper special with a 352 FE engine......i have heard this truck is rare......should i just lift it and put 35"tires on it or should i do a 4x4 swap.....also for a 4x4 swap what would i need to swap and from what year truck to mine
thanks
It ain't rare.
Converting a 2WD to a 4WD is doable but it's alot of work. Most will say simply get a 4x4 to start with.
Read these for background.. the principles are the same. Then evaluate if you have the time, facilities, tools, money, and know-how.
2WD to 4WD Conversion
4WOR Magazine: Project Two-by Four (4x4 Conversion)
FTE Thread: Quadrazer's F350- 2WD to 4WD Conversion...
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
towtruckerfour
Post by towtruckerfour »
When I did mine, I had a 70 2wd and a 68 4wd. It was pretty easy to put the 70 body on the 68 frame. I used my engine puller to swap everything. The cab was the hardest part.
Troy
