Does anyone know what these go to......update 8-7-2013
Re: Does anyone know what these go to......update 8-7-2013
Is that the Harbor Freight trans. jack? Curious to hear a review of it!
I actually have installed the trans already, pretty much did what you stated. Thank you for the advice thou.Donnie wrote:Before you install the trans, make sure that your converter is all the way into your trans...There are 3 things that have to engage, 2 sets of splines & the pump gear's. Make sure that you attach the trans to the engine first then wiggle your converter bolts, you should have between 1/16 & 1/8 inch of clearance between your flexplate & your converter.....DON'T FORGET TO FLUSH YOUR COOLER & INSTALL AN IN LINE FILTER IN THE RETURN LINE.........that is the rear line.......Blowing air thru the lines WILL NOT flush contamination out, but the NEW hot trans oel will.
Ask your builder if he put a magnet in the pan....Whose converter are you using? Don't know, ASK.....there is a lot of $99 dollar specials out there.......
The jack did great I recommed it if your going to do this project. Glad I purchased, I was going to rent one but it cost to much.72BahamaBlue wrote:Is that the Harbor Freight trans. jack? Curious to hear a review of it!
Thank youtbone6 wrote:Lookin good!
