What is this
How's your Ford truck parts knowledge?
69Ford
Re: What is this
Post by 69Ford »
After doing more research I believe it is a circuit breaker. Its on a wiring harness with a firewall plug. It looks to me like this is on the engine side of the firewall. Do not know what
the harness is for I did not take it off. Thanks
1969 Ford F100 Styleside standard cab 360 C6
1968f250429
Re: What is this
Post by 1968f250429 »
That is a circuit breaker found on the camper wireing circuit.
As my truck has the same thing under the right hand side of the dash. With the light relay.
69Ford
Re: What is this
Post by 69Ford »
Thanks the part was with a wiring harness I purchused.
Massauto
Re: What is this
Post by Massauto »
Called a fuse block I believe.
1968 F350 Dually Utility Body
Everybody wants to paint....nobody wants to sand.
Busboy
Re: What is this
Post by Busboy »
Self resetting circuit breaker.
1967 F-100 4x4 custom cab.
