360 to 390 build
- 69f-100
360 to 390 build
Well here it goes, I'm doing my first 360 to 390 build. Engine is all torn down and just sent block over to machine shop for machining. Will have pics soon of my progress. Not doing anything extreme, but definitely going to "wake" it up some.
- speedbug78
Re: 360 to 390 build
Sounds like fun! What are your plans for "waking it up"? Cam, intake, exhaust? It'll be fun to see pics when you get them. What machine work are you having them do, basic bore and hone, or are you going for more?
- 69f-100
Vodoo cam http://www.lunatipower.com/Product.aspx?id=2375&gid=297, valve springs, edelbrock rpm performer intake, holley 750, and speed pro flat top pistons. I'm having it bored, decked, and the oil feed holes in the main bearing saddles fixed. I almost forgot about the 390 crank and rods.speedbug78 wrote:Sounds like fun! What are your plans for "waking it up"? Cam, intake, exhaust? It'll be fun to see pics when you get them. What machine work are you having them do, basic bore and hone, or are you going for more?
- wndsofchng06
I will definitely be following this thread!!! I want to wake up my 360 also!
- 69f-100
No updates as of yet, still at engine shop. I will post more updates as they come.
- 69f-100
I have finally have some updates. The 360 that was in it had already been bored .040 over and had two sleeves in it. The cylinders had to much wear in them to get them to clean up, so I ended up getting a DT4E block from the engine shop for 50 bucks ( didn't think that was too bad). I have the block and everything back, now just waiting on it to warm up so I can get started on the assembly and paint. I have a bunch of pics of the things I have so far for my build.
Chamfered main bearing saddle holes on mains 1,2, and 4.
390 crank
Reman heads with new valve springs for my Voodoo cam
Sealed power .030 flat top pistons with moly rings
Felpro gasket kit, bearings, oil pump, timing chain and gears, etc.
Camshaft and lifters
Rocker shafts
Reconditioned rods with new wrist pin bushings
390 crank
Rocker shafts
- wndsofchng06
Good deal!!
- F100builder
Looking good so far! I have a similar one going together now that's in a time out for now as I'm getting the rest of my '70 ready for it. I used a Voodoo cam as well and can't wait to hear it! I'll be following along as I'm sure you'll be turning the key before I do.
Patrick
- toddspeed
I am itching to do this - any idea what you think this will cost you for engine parts/labor? Not including your time to R&R the motor....
Todd in Atlanta
1970 F100 Ranger born the same month/year as me - 360 C6 2WD, P/S, LWB
You! Yes You! Please put your location in your profile - it helps us help you when it comes to parts, pricing, and advice.
- 69f-100
The only labor was at the machine shop, I think that was around 800.00. that was for all of the machine work to the block, rods, and rocker arm shafts. I think i'm gonna be around 2,000 to 2,500 when I'm completely finished.toddspeed wrote:I am itching to do this - any idea what you think this will cost you for engine parts/labor? Not including your time to R&R the motor....
- 69f-100
Cam looks a little dry. Cant see and break in lube? Optical illusion?
1968 F250 Camper Special 390
1964 Galaxie hardtop 352
1967 Cougar project
1993 F350 Crew cab 5.8
1988 Bronco 5.8 C6
1966 Mustang fast back project
New 1962 Falcon Gasser project
1967 Cougar project
1988 Bronco 5.8 C6
- 69f-100
Optical illusion, it's coated really good.SecondCamperSpecial wrote:Cam looks a little dry. Cant see and break in lube? Optical illusion?
1967 Cougar project
1988 Bronco 5.8 C6
1967 Cougar project
1988 Bronco 5.8 C6
- 69f-100
Nice, looks real good.
