1967-1972 F100 parts trucks
- rmurphy
Re: 1967-1972 F100 parts trucks
sold drop axels, do have two under dash a/c units. $50 and the ride. send u pictures of both
- rmurphy
- timmytim
need 4spd trans hump
buy'em dirty sale'em clean
get more money for the same
machine.....
My 1967 bump: http://www.fordification.com/forum/view ... 09#p668209
My 1970 Bump: http://www.fordification.com/forum/view ... 16&t=50726
- rmurphy
had one for 3/4 ton let me see if i still got it. (is this it?)
Any chance you'd have a NON-A/C heater box that'll fit a '72 250? If so, do you have the dash slider controls too? Thank you!
- rmurphy
PhyrPh0enix wrote:Any chance you'd have a NON-A/C heater box that'll fit a '72 250? If so, do you have the dash slider controls too? Thank you!
yea I have the box and controls.
how much for the box and controls shipped to 20190?
just to make sure, that's WITHOUT A/C... cause I'm tired of screwing with the old A/C and all its unavailable parts!
1972 Ford F-250 Camper Special 360/C6
- timmytim
That looks like the hump but im not sure if 3/4 hump is same size as the 1/2 humps. Maybe somebody can tell us for sure...
machine.....
- rmurphy
I built a 68', used a trans cover from auto. 79' 4x4. cut out the hole and it fit perfict. the indention is in the tunnel aready. Bolt holes are marked. Pm sent on price.timmytim wrote:That looks like the hump but im not sure if 3/4 hump is same size as the 1/2 humps. Maybe somebody can tell us for sure...
- rmurphy
I too am looking for the short harness in the engine compartment that goes to the distributor and also looking for a good set of rails that holds the door glass
- rmurphy
are u needing the metal window channel that goes down the back side of the door? check on the wire.
- timmytim
check your inbox buddy
machine.....
- rmurphy
I found the wire. (someone has but connections on the ends. take a LOOK)676870F100 wrote:I too am looking for the short harness in the engine compartment that goes to the distributor and also looking for a good set of rails that holds the door glass
