To high rmp?
To high rmp?
Ive got a 70 f100 302/c4 and at 45mph its running about 2k does that seem right? I can feel it shift 1-3 by 30 im high gear. Olny thing not hooked up is the kickdown.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- BobbyFord
Re: To high rmp?
What is your rear end ratio?
Re: To high rmp?
i think its 4:10 or 4:11 theres not tag so im not a 100% sure
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- BobbyFord
Re: To high rmp?
You can always decode your warranty plate for the original gear ratio. A taller rear gear will lower your final drive rpms.
Re: To high rmp?
i believe the rear end was changed cause its a 9 3/8. i also got 295/50/15 on the rear
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
Re: To high rmp?
What is the distance from the ground to the top of the tire.? I posted before, the method used to find your rear end ratio if it has been changed & all tags are missing or inaccurate....The moderator can guide you to this info.........post back your tire measurement & someone will help you...Donnie
- BobbyFord
Re: To high rmp?
What is the axle code on your warranty plate?
Re: To high rmp?
it says axle 08BobbyFord wrote:What is the axle code on your warranty plate?
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- BobbyFord
Re: To high rmp?
08 is a 3.50 ratio.
The fact that you have no tag on your diff suggests that its not the original rear chunk
- elgemcdlf
Re: To high rmp?
My 3.55s turn 2400 at 55 mph.
