Brandi, Project Beast to Beauty - 6/03/10 Questions
72Highboy
Re: Brandi, Project Beast to Beauty - 6/03/10 Questions
Post by 72Highboy »
Just a quick question I was wondering how much does this topper weigh? :hmm: Its only me, my wife and my father-in-law to move it. Its kinda getting in the way and I really don't any need for it till the winter. Im not sure what brand or model it is but it's an 8ft topper. :?
Joshua
aka Young Gun 8) :drive:
FE - Famous Engine
(Brandi) 72 F100 360 5.9L Sport Custom 6" Lift
U.S. Army Veteran/11B
Ranchero50
Post by Ranchero50 »
Shouldn't be over 300lbs. I'd suggest just loosening one side and see if you can lift it. That truck is long enough to put a hot tub in the back cab. :thup:
Jamie
koch68
Post by koch68 »
How do you get your head lights and markers om at the same time. My markers shut off when I turn on headlights
Taylor-
1968 F250 Highboy np435 dana 24 4.10's
DCrusher
Location: Hurst,Texas halfway between Dallas/Fort Worth
Post by DCrusher »
koch68 wrote:How do you get your head lights and markers om at the same time. My markers shut off when I turn on headlights
Here's a thread on that very easy to do I haven't done my yet I just put my dash back in and remember that I wanted to do the samething so I pulled the dash back out and noticed that you can get to it from under dash. About half way down you see the wiring diagram. Hope this helps.
http://www.fordification.com/forum/view ... =8&t=48178
http://www.hottottyscreations.com
55 F-100
57 Oval VW
68 F-100 3" Dropped Axles & Rear Hanger Flip
88 Dodge Ramcharger
97 F-150 Extended Cab 4" 6" Slammed
72Highboy
Post by 72Highboy »
Koch68 sorry to throw anyone off by my username my truck is a F100 not really a highboy. The cab marker lights are some I bought from harbor freight. Its wired to switch that I mounted to the bottom of the dashboard. So I can run them independently to all the other light. Another way is to take a test light and probe wire by the light switch and find the wire that goes to the running lights. Once you find them just use a clip and tap into that wire. I personally like just using switches they look cool to me and it eliminates any confusing when there is a problem. If you would like any other pictures just let me know. Ill snap some up and post them.
Joshua
FE - Famous Engine
72Highboy
Post by 72Highboy »
In this picture you can see down below the ignition hole there is the switch holder. That one is actually to my 2 off road lights mounted by the top bumper bolts. Custom brackets I built in my AG shop. There were two existing holes that were on the bottom and I just took a plastic divider to one of my accessories wire boxes and used a razor blade to cut a opening to hold the switch and used a lighter to heat the plastic and bent it to how I wanted it. Works perfect and is very inexpensive.
Joshua
FE - Famous Engine
