Project "I Must Be Nuts" - On the road!
CrypticRacer13
Re: Project "I Must Be Nuts" - Nearing the end
Post by CrypticRacer13 »
Words can not describe what im looking at my friend. looks fantastic
-Mike-
ECV 1849
Wow! Looks great. I can't wait till I'm that far along. :thup:
71PA_Highboy
Post by 71PA_Highboy »
guerra wrote:That looks real good!! :thup: What color red is that?
Porsche 'Guards Red'.
Thanks...
Due to location (NW PA) it will be a 5 footer.... at 5 foot it looks great.... but I already see some flaws I wish I could re-fix, and some pieces that were bad enough that I wanted to replace them, but no parts were reasonable within distance/cost....
I am building it as a working truck with concours aspirations.... ;)
sargentrs wrote:Wow! Looks great. I can't wait till I'm that far along. :thup:
Give yourself an unreasonable timeframe with significant consequences for failure and it is amazing what you can get done...
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
71PA_Highboy wrote:Give yourself an unreasonable timeframe with significant consequences for failure and it is amazing what you can get done...
:lol: I like that!
tylerb43
Post by tylerb43 »
That looks awesome, man! You've made huge progress in a short amount of time! I'm really looking forward to the reassembly stage, always a fun time, where significant progress is made every day. - very cool. :thup:
I always set unreasonable deadlines and goals for myself, but unfortunately, I know I'm full of crap. :D
71PA_Highboy
I am moving 300 miles away on 1 Aug.... this is a deadline that has consequences high enough you would meet them...
otherwise I am usually in the same boat... :wink:
Got Ford?
1 Lincoln Mark VIII
71PA_Highboy
smokey3215 wrote:Wow the truck is looking awesome.hopefully it will still be there when I come up at the end of the month.
It will still be there... Hopefully it will be MUCH further along....
Got Ford?
1 Lincoln Mark VIII
71PA_Highboy
Yesterday's prep work:
Column is ready:
The wheel is shot, and I plan on replacing it with something else, but it will do for now...
Booster is in:
I am missing one of the fittings for the brake lines, so I will get that today and get the brakes plumbed...
Door Latches are clean and ready:
The previous owner(s) liberally covered these in white lithium grease... they were so sticky that they were hard to actuate - even in 80 degree heat.
An 8 hour soak in a gallon of carb dip cleaned tham up well, then a rinse in the parts washer to remove the final gunk. Also removed all the overspray from the previous paint job :thup:
Wing window windchimes:
Yes, there are only 2 in the truck, but I know if I just do 2, one will have to be re-done... if I do all 4, then they will all be good and I will have 2 nice spares (that is the way my luck goes...)
Door panel:
I am going to use the black Ranger panels, so I thought the gray would be an interesting highlight/offset color.
Anyway, yesterday was mostly prep, so today I should actually get some assembly done! :pray:
Got Ford?
1 Lincoln Mark VIII
Great work! Can't wait to see the finished product.
71PA_Highboy
I count today a MAJOR milestone. :woohoo:
All the wiring is in, tested, and almost all is working...
Since the underdash wiring harnes was in bad shape (too many previous owners and too much rust), I have spent a lot of time cleaning this one up (Fuse box actually had the wires rust off the clips) and I had many concerns (converting it to F600 in there too).
The Starter solenoid is bad, so I will pic up a new one tomorrow, and then the final test (starter) will be done.
I am waiting on my HEI dizzy and a fuel tank, but I should be able to start it soon.
The brakes are plumbed and ready to be bled. May get to that tomorrow if I can get some help.
Exhaust is in... Nothing special but it will keep me legal.
The wing-window windchimes are painted and looking good.... waiting on parts from MACs... :x
Speedo cable is in. Ebrake is in and adjusted.
Doors are adjusted and outside handles are on.
Retainers for cab rear beltline installed.
Found a 68 highboy in the JY so I may have found the right gas tank mounts and gas tank...
Always too much more to do, but I am getting there...
Got Ford?
1 Lincoln Mark VIII
71PA_Highboy
Re: Project "I Must Be Nuts" - On the Road!!!
Drive 300 miles tomorrow....
:D
She's not done, but she is done enough to move her to her new home... :woohoo:
I'll Check back tomorrow night and let you know how the trip went...
g'night all!
Got Ford?
1 Lincoln Mark VIII
Fordnatic
Re: Project "I Must Be Nuts" - On the road!
Post by Fordnatic »
Looks AWESOME!!
55F100
basketcase0302
Post by basketcase0302 »
Congrats on a nice build, hope her maiden voyage went well. :thup:
cheek
Post by cheek »
Daaaaaaamn, that's some really nice work you've done in a real short amount of time!
1970 Ford F100 351C FMX Daily
1972/3 Ford F100 Project
smokey3215
Post by smokey3215 »
Looks great Eric .
