rear end swap
- boozer68
rear end swap
i need disk brakes in rear of my 68, i heard about the explorer rear end. is this a good swap or is there a better way. i hae the CV front ifs already installed, i want to match the bolt pattern so i can rotate and atleast clear p confusion of the rim and tire idiots!!!! can some one send me a link or a thread as to the best option without spending a fortune
- elgemcdlf
Re: rear end swap
If you are wanting to stay with a solid axle the Explorer is a very good option. 31 spline along with discs if you grab 1 that has discs. Many came with Limited Slip (look for an L in the gear ratio on the tag) & you can get quite a host of ratios.
Re: rear end swap
Explorers from 1995-2001 came with disc brakes. Prior to '95 they had drum brakes.
If you're searching Explorers in the wrecking yard to find a suitable rear end, it's easier to look on the driver's side door/door jamb at the data tag, for the rear end ratio, than to crawl under every one of them to get a look at the tag on the rear end.
Under the "Axle" heading of the door/door jamb tag will be a pair of numbers or an alpha-numeric code. A pair of numbers denotes a single track differential. An alpha numeric denotes a Traction-Lok differential. --gear ratios and differentials can be changed.
Explorer axle codes:
43=3.08 ratio
41=3.27
42=4.10
45=3.55
D4=3.73 (Traction-Lok)
D2=4.10 (Traction-Lok)
This is an 8.8" Explorer rear end I pulled from a '96 Explorer. It has disc brakes and 31-spline axles. It does not have a Traction-Lok differential but it does have 3.55:1 gears.
Possible 8.8" ring & pinion ratios that could be swapped into the rear end: 2.73, 3.08, 3.27, 3.31, 3.55, 3.73, 3.90, 4.10, 4.30, 4.56, 4.88, 5.13, 5.71 or 6.14:1.
43=3.08 ratio
41=3.27
42=4.10
45=3.55
- rusty2872
Re: rear end swap
ultraranger,
are those explorer rear ends a direct swap, or will there be welding and relocation involved? Also what is the bolt pattern usually?
Russ
1969 F100 CS
1969 F100 CS
Re: rear end swap
I had actually bought the Explorer disc brake rear end a few years before I even had the '69 F100. I actually bought the Explorer rear end for a possible swap into a '68 Mustang, so I don't know all the particulars about what's required to swap an Explorer rear under an F100. A websearch would probably come up with the information.rusty2872 wrote:ultraranger,
I do know the '95-2001 Explorer rear ends have disc brakes, 31-spline axles and usually good ratios --but not all have Traction-Lok differentials. They also have larger axle tube diameters than the F100s --3-1/4" dia. vs. 3.00" dia. If you got one, it would be good to get the U-bolts and spring/shock perches and the parking brake cables too. They have the same 5-on-4.5" lug pattern as the Crown Vics (same as '94-current Mustangs and is even the same lug pattern as my old '68 Mustang).
However, the Explorer rear end is a good bit narrower than the Crown Vic front assembly so it would require a pretty deep dished rear wheel compared to the front wheels.
A 2003-2011 Crown Vic front supension has a wheel flange width of 66-7/8" wide. The Explorer disc brake rear end width is 59-3/4" wide. --a T-Bird disc brake IRS rear end assembly has a width of 63-3/8".
I'm not certain of the width of a '2003-2011 Crown Vic disc brake rear end but other than the fact it may not have 31-spline axles, it would seem it would come closer to being the same width as the Crown Vic front suspension assembly.
Re: rear end swap
not trying to hijack the thread ,but i've been toying with the idea swapping out the 9" in my truck for an 8.8 lately (disc brakes not totally a neccessity) ...
so i wondering if anyone knows off hand what the width & etc of a fullsize car (like a crown vic or lincoln town car ) 8.8 is ?
Re: rear end swap
What about a F150 axle from a newer truck?like they did on fast and loud.
Re: rear end swap
I'm not certain what the rear end width of a late model F150 is but the rear disc diameter is 13.7" (nearly 13-3/4"). This would put larger discs on the rear than the front --if you were installing a Crown Vic front suspension. CV front discs are 12". The lug pattern would not match the CV's lug count or spacing.Amosf10072 wrote:What about a F150 axle from a newer truck?like they did on fast and loud.
The F150 rear brakes are of a single piston caliper design and the rotors come in a 6-lug 130mm lug pattern or a 7-lug 150mm lug pattern.
The F250 diesel trucks have 8-lug discs on a 170mm lug pattern with 12.83" diameter rotors. They also have twin-piston rear calipers.
