for sale $195 1970 Ford F250 2wd DISC BRAKE front i beams
Private parties only. No eBay/Craigslist listings.
tubolove
Post by tubolove »
Selling a COMPLETE drivetrain (see other listing) and COMPLETE front axle with disc brakes from my 1970 F-250 Camper Special. $195. Perfect for an OEM bolt-on front disc brake conversion on 67-72 F series trucks. It has the large discs with dual piston calipers in place. Recent new pads. If you want it there is an aftermarket swaybar with polyurethane bushings included on the axle. Power brake booster with master cylinder and proportioning valve from the same truck available for $50 extra. Note these are heavy duty 8 lug man-truck axles.
If needed for an additional $195 I also have a complete 8 lug dana 60 rear axle assembly with leaf springs and frame brackets still intact for a heavy duty bolt-on 8 lug rear if you want to upgrade to that as well. 3:54 gears
Truck has 107k orig miles. If engine and trans has not sold then you can drive before you buy!
gregamorton
Re: for sale $195 1970 Ford F250 2wd DISC BRAKE front i beams
Post by gregamorton »
Why in the world are you tearing this truck apart?
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 3.73s rolling on 19.5s
1971 sport custom on 1979 f350 highboy frame 460 c6 np205 dana 60s 3.54s
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1990 F250 extended cab FI460 e40d 3.55s daily driver
Possibly looking for my next bump right now!
Effie_70
Post by Effie_70 »
where r u located I am definately interested!
tubolove
Post by tubolove »
Effie_70 wrote:where r u located I am definately interested!
I am in Deland, FL. Too bad I had to wait to sell this after I moved but I was in the upstate of SC. A lot closer to you!
tubolove
Post by tubolove »
gregamorton wrote:Why in the world are you tearing this truck apart?
Here's a link to my build thread on here:
http://www.fordification.com/forum/view ... 22&t=61734
Check it out!
mjackson
Post by mjackson »
too bad you're about as far from me as possible. :(
