Looking to go Tremec on my resto/rod build
69rangerf100
Post by 69rangerf100 »
So here are the specs on the current setup
Engine - 6.4 390 30 over
Trans - 3 spd manual
rearend - D60 5 lug 3.54 gear
What i am thinking is going to either the 5 or 6 speed Tremec so that i can try and get some better MPG out of it.
So here are my questions that i am not sure of how to figure out so that i get the correct tranny.
1. How do i figure out the length on the input shaft or does anyone know what it would be.
2. With the spline count what is the typical count used.
Am i forgetting anything that i may need to know?
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
BobbyFord
Re: Looking to go Tremec on my resto/rod build
Post by BobbyFord »
I'd try their tech support. There's email and phone info here...> http://www.tremec.com/performance/contactus.php
HIO Silver
Post by HIO Silver »
I'm planning on a Tremec TKO-500.. you'll need a 1-1/16-inch, 10-spline input shaft, a Quicktime bellhousing, and a new clutch.- mechanical, cable,or hydraulic.. and the commensurate driveshaft modified for your application - short bed or long bed.
With a 0.68 overdrive (5th gear), you'll need to run a 4.10 rear gear so the final drive equals 2.79 which is an excellent highway gear. A 0.68 with a 3.50 pr 3.54 rear gear calcs out to about 2.40 which is waaay to low for the typical FE.
The cost will be around $4000. Contact Hurst Driveline Conversions for tech help. http://www.hurst-drivelines.com/?page_id=1014
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
69rangerf100
Thanks for the great info. HIO Silver thanks for the rough estimate i was curiouz at what i was going to run me.
David
