What year axles will fit my 69 F250 Highboy
booblinker
Post by booblinker »
I locked up the axle on my highboy, I need to scour craigslist to find an axle. What years will fit? I have found some ford axles with the right gear ratio and lug pattern, just want to buy something that will bolt in relatively easily.
1969 F250 High Boy 360 4 speed
-3" Body Lift
-36x12.50 tires
-Edelbrock Intake, Mallory Distributor and coil, long tube headers, and true duals with flowmasters
-Who knows what else I haven't figured out
-1993 Ranger 3.slow 4x4 DD
-1971 F100 302 auto
-1985 Tri-z
-ATC70 with a 125 motor
-A few 200s's
71PA_Highboy
Re: What year axles will fit my 69 F250 Highboy
Post by 71PA_Highboy »
I have a pair just waiting for a buyer...
Where are you?
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
booblinker
I'm by Detroit, mi. Sadly a little to far from you, unless you come out this way.
-3" Body Lift
-36x12.50 tires
-1971 F100 302 auto
-1985 Tri-z
-A few 200s's
71PA_Highboy
I will go as far as Cleveland... I-90 and I-271.
Got Ford?
1 Lincoln Mark VIII
booblinker
No one? I can find 70's axles, will those work, or will I need to move the leaf mounting point?
-3" Body Lift
-36x12.50 tires
-1971 F100 302 auto
-1985 Tri-z
-A few 200s's
1972hiboy
Post by 1972hiboy »
I think up to 77.5 dana 44 will work. obviously 67-72 should be completely bolt in. the later axles might need minor stuff like brake lines? im kinda guessing but should bolt in. Ive got a complete axle sitting in the barn but as well im kinda far.....
Rich
Dont eat yellow snow.....
booblinker
Well doesn't matter now. Had it towed from the mechanics, he couldn't get the axle shaft that was locked up off. He tried an air hammer with the bolts outta the flange and it wouldn't come out, so I was gonna find a whole used axle to put in myself. I decided to try myself, I unbolted the 8 bolts in the flange, put it in granny gear, let out the clutch, and ping the axle shaft came undone and shot out over a foot, almost hit my truck beside it(Took some big block torque to get it out). The spindle nuts came loose, and jammed against the axle shaft. I got it all apart, luckily all I need is bearing and races. Inner bearing spun, but luckily didn't mess up the spindle.
-3" Body Lift
-36x12.50 tires
-1971 F100 302 auto
-1985 Tri-z
-A few 200s's
