69 manual steering column non-shift
Sunwings
Post by Sunwings »
:help: I need a good or average steering column for my 69 f-100 straight non -shift - no power steering. need it complete with rag joint. they are hard to find one around here in south west Oregon. reasonable. thanks.
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
TNIceWolf
Re: 69 manual steering column non-shift
Post by TNIceWolf »
That is one of the most easily rebuilt columns out there for bumpside trucks. Parts are available from LMC....NPD....and Dennis Carpenter. Even the rag joint is usually available through most of the chain type parts stores. Why go for a used worn unit when you can just as easily refurbish what you already have?.....Just a thought.
Presently in the stable
1969 Ford F-350 DRW
Sunwings
Post by Sunwings »
the previous owner drove it with bad cab mounts and blew out the bottom bearing so bad the the shaft is also bad. I can no longer hold the bearing properly.
TNIceWolf
Post by TNIceWolf »
If you can get me an accurate measurement I think I have one of those shafts sitting here for a manual steer truck.
1969 Ford F-350 DRW
Sunwings
Post by Sunwings »
I will see what i can do.
It's a shame nobody repops the steering shafts. You can get just about anything else but those. You could always take it to a machine shop and they can refurb or remake one for you. Hopefully Charlie will have one for you.
Sunwings
Post by Sunwings »
I agree.
danno
Post by danno »
I got one if you still need it,PM me and I will send you some pictures
65 f-100 4wd short bed 360engine c-6 tranny
jzjames
Post by jzjames »
the steering shaft on mine had a bad cut in it. When I looked at it I could see I could fill the cut with JB Weld (smooth it to shape) and the bearing would work with it. I threw it back together and no worse for wear.
