More done on the 72'...
tylerb43
Re: More done on the 72'...
Post by tylerb43 »
Awesome, Todd! That is one highly desirable rear end! :lol: My brother-in-law (rock crawler) would drool all over that picture.
Keep it moving, bud! Very interested in all the cab metal and frame fab work, excellent! :thup:
1972hiboy
Post by 1972hiboy »
HEy thanks for finding my front end! ive been looking everywhere for it! you can go ahead and bring it on down ill give you gas money and buy you lunch..... :wink:
Really amped to see your project coming along.
Rich
Dont eat yellow snow.....
zakt
Post by zakt »
got the 2x4 crossmember, looks pretty good.
1972 Ford F350 crewcab
averagef250
Post by averagef250 »
That does look pretty nice.
zakt
Post by zakt »
ripped the bump stop bolt right off trying to get it out... thought I wasnt going to get it :cry: but ended up sacraficing a socket to get it out and save the knuckle. All that NY rust.... got the newer hubs with the 9/16" studs vrs the 79 1/2" studs. Pulling the knuckles this weekend and start cleaning it and start putting together. Having a problem though finding a good set of 86-91 front brake calipers form a D60.. so that will be a hold up.
CrypticRacer13
Post by CrypticRacer13 »
Cant wait for the install.
-Mike-
ECV 1849
71PA_Highboy
Post by 71PA_Highboy »
How are you going to mount the drivers side shock... As far along as I am, this is the problem I face.
If you go crossover steering it isn't a problem, just the original push/pull.
Let me know what you decide so I can get mine done!
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
zakt
Post by zakt »
Im going crossover 8" or 10" lift but will be putting dual shock mounts into the top of the leaf spring hanger (if all goes well) here is what im thinking....I also want to do the ubolts from the buttom with nuts on top (with below)
http://www.barnes4wd.com/U-Bolt-Plates- ... p_140.html
71PA_Highboy
I can understand wanting to do that but how do you intend on allowing for the inner U-bolt to be mounted with the ribbing on the bottom of the housing? Please don't say you are going to notch it....
Got Ford?
1 Lincoln Mark VIII
zakt
Post by zakt »
hum.. they say it will slip if not notched (dont want to notch housing :thup: ). Might just then stick with the original setup and put the shock mount on it like the above. I dont like the stock setup one of the holes is already oval..
zakt
Post by zakt »
some guys actually drilled a hole for the u-bolt, dont think I want to do that :loco:
71PA_Highboy
That is probably stronger than notching it...
I went with the original caps... just for that reason.
Got Ford?
1 Lincoln Mark VIII
averagef250
The Ford style U-bolt mounting is a lot more durable/stronger. Why would they spend more to do it that way? Why don't big trucks use round U-bolts?
Some things you may ask yourself.
Many do notch and drill the housings though. I've done it for others, but will keep the square U-bolts myself.
zakt
Post by zakt »
Arg.. the rust.. ripped off the head of another bolt on the bottom king pin cap. Will cut off the cap and hope 1/4" or so of the bolt should be left, weld on another socket....
FormerMarine1981
Post by FormerMarine1981 »
It's only one bolt left, can you spin it off of the rest of that bolt or is the plate recessed into the housing to where it can't spin? I don't know anything about the front axle.
Last edited by FormerMarine1981 on Mon Jul 23, 2012 12:35 pm, edited 1 time in total.
