72 crew cab cummins
averagef250
Re: 72 ford crew cab
Post by averagef250 »
what's the plan with the wire size/protrusion?
smokey3215
Post by smokey3215 »
i have to look but i think it is .032 ss with a .011 protrusion. I have this same setup on my superduty cummins swap i run 60 lbs of boost daily and nos once in awhile and havent had a problem in 3 years. So i am sticking with if it aint broke dont fix method we will see what 500-600 hp will do to it lol.
KRob
Post by KRob »
Could you post some more pictures of how you did the Dana 60 swap that is a very interesting route. If a guy didnt want to lift his truck or leave it as close to stock height as possible could he do it using your method?
THanks
Rob
71 F250 4x4, 4BT Cummins Mostly Done...Project Thread http://www.fordification.com/forum/view ... 22&t=65450
(4BT, big block ZF5, 78 NP205, 78 Dana 44 Front axle, 4.10, 265/75/16, power steering, power brakes)
01 Dodge 2500 4x4 Cummins...turned up a little.
smokey3215
i will try to get more pics of it posted up you could use the stock height i just wanted to use the ford superduty springs because of the weight of the cummins engine.
smokey3215
alright guys got some stuff done along the last couple weeks. I got the entire shortblock done all new gaskets bearings orings in the block arp head studs and rebuilt the p/s pump. I also got started on porting the head. My plan is to have the entire drivetrain rebuilt by the beginning of summer and in the frame for a test fit .
1972hiboy
Re: 72 crew cab cummins
Post by 1972hiboy »
:pop: :pop: hows this project going?
Rich
Dont eat yellow snow.....
smokey3215
It's moving forward the motors complete the trans rebuilt and transfer case. I got the 300 out and started boxing the frame. I will get gome new pics up soon.
tybob81
Post by tybob81 »
:pop:
smokey3215
Just trying to see if this works
smokey3215
smokey3215
smokey3215
smokey3215
smokey3215
Alright as promised I got a few more pics up of finished motor trans and the 300 getting ready to come out. I have more just have to download them.
smokey3215
Got the majority of the frame boxing done. And had one of my buddy's cut me some motor mounts. Now I just have to gring the frame. And in with the trans and motor.
