power steering problems
fattyford
Post by fattyford »
I have a 1970 ford truck with new power steering pump & hoses.Everything is hooked up right, but when I turn the steering wheel it turns about six inches then locks I take off the tension and it turns about six inches and does the same until turn is completed.
fireguywtc
Re: power steering problems
Post by fireguywtc »
:wel: from Texas! :fr:
Bill
basketcase0302
Post by basketcase0302 »
:wel: from choo-choo town. Sounds to me like it's in the steering box, (even rebuilt ones can have issues) is there a warranty on it? But I'd also try to "burp" the system first. Do this by jacking the front off the ground-and go from lock to lock a few times to make sure it's not air in the hydraulics causing issues.
:wel: from Georgia!
wndsofchng06
Post by wndsofchng06 »
welcome....
Was it steering ok before you replaced the pump?:
tidybowl
Post by tidybowl »
Welcome to the world of Bump fun from SoCal. Sounds like a hydraulic lock up. If you have enough hose, remove the return line to the pump put a bucket under it to catch to fluid and put extra hose on the pump that can rise above the pump (a second had is always helpful. Have PS fluid and a funnel at the pump. Start the motor. With a second hand adding fluid to the pump, quickly check the steering. If it works, and you have good flow on your return, the pump is defective. If you have little or no flow on the return line the steering gear may be plugged. I've used air to back flush the steering gear. Repeat the the procedure. Good luck
1970 F-250 Camper Special 390/C-4 auto 289K miles, 1992 Explorer 4x4 229K Miles, 2000F-150 4.2L V6 154K miles
fattyford
Post by fattyford »
Thanks guys looks like I had an air lock in the hose, good burp everything work well.
basketcase0302
:woohoo: love easy fixes! :thup:
Kurt Combs
Post by Kurt Combs »
:wel: from northern California! Glad to hear you fixed your problem.
Kurt
1972 F-250
