67 Shortbed 2WD Rebuild
- MattHillFord
Re: 67 Shortbed 2WD Rebuild
Finished coating process yesterday. Taking a day off, then its down too the fun stuff (engine) tomorrow.
4/2/2012 (Yesterday)
Finished coating frame and firewalls.
1967 F100 RWD Short Bed / http://photobucket.com/MattShortF100
1968 F100 4X4 Long Bed / http://photobucket.com/MattLongF100
Project Page:
http://www.fordification.com/forum/view ... 22&t=65244
Project Page:
- MattHillFord
4/5/2012
Just got done with almost all the engine work. Ill have more pictures over the weekend, but here is a quick update!
Almost all done with engine work.
Project Page:
Project Page:
- F100builder
Outstanding!!! It looks like you've used the cork front and back intake gaskets??? It's of course up to you but I would strongly recommend NOT using them...Instead, put a 1/4" bead of silicone on them and let it tack up a little before installing the manifold. This will save you from a headache of an inevitable leak...FE's and pretty much any motor commonly leak here. Another thing that I usually do is put dimples along the rails with a sharp center punch and a light tap with a ball peen hammer. This gives the silicone 'grip' and keeps it from pushing out like the cork and rubber gaskets almost always do (or at least leak). Below is a pic of my stroked small block. If you look closely, you can see the dimples along the front and back rails.
Anyway, your progress is looking real good and I can't wait to see more!
Patrick
- mybros71
This truck is looking very clean. I was just curious, what was your dad welding on the frame?
Keep up the good work.
Tony
Tony
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
- MattHillFord
Yeah, I went with the cork... I know, black silicone is on top and bottom of it, but it will be replaced. My money for this build was limited so a cheap Mr. G rebuild set was in order . And the intake and block was tapped, but something was needed because the space in the intake to deck was more then expected. The deck had been shimmed at some point already.
And someone tried too pull something with the frame and it pullout a hole in the front of the frame. My dad welded it back and turned it back to good as new.
Project Page:
Project Page:
- mybros71
He did a pretty good job, I couldn't see the repair.
- MattHillFord
Yeah hes way better then me at all that.
Project Page:
Project Page:
- MattHillFord
Project Update - 9/4/2012
Ok did some more engine work today and started to rebuild the distributor.
Got care package from LMC, got engine compartment rubber like the hood to cowl gasket (Thanks for the tip Basketcase0302) and some random seals and hood bumpers.
Replaced all of the internals.
Here is a almost finished project, gonna polish it up soon.
New Plugs.....
Water punp, Fuel pump, and Oil filter arm/Oil filter CHECK.
New Plugs.....
Project Page:
Project Page:
- BobbyFord
Interesting. I usually drill 3/16" holes about 1/4" deep in the aluminum intake ends and then fill the holes with silicone before running the bead on the block surfaces.F100builder wrote:...Another thing that I usually do is put dimples along the rails with a sharp center punch and a light tap with a ball peen hammer. This gives the silicone 'grip' and keeps it from pushing out like the cork and rubber gaskets almost always do (or at least leak). Below is a pic of my stroked small block. If you look closely, you can see the dimples along the front and back rails...
- F100builder
Also a good idea...a little more work though I suppose.BobbyFord wrote:Interesting. I usually drill 3/16" holes about 1/4" deep in the aluminum intake ends and then fill the holes with silicone before running the bead on the block surfaces.F100builder wrote:...Another thing that I usually do is put dimples along the rails with a sharp center punch and a light tap with a ball peen hammer. This gives the silicone 'grip' and keeps it from pushing out like the cork and rubber gaskets almost always do (or at least leak). Below is a pic of my stroked small block. If you look closely, you can see the dimples along the front and back rails...
Patrick
- MattHillFord
4/23/2012
Well its been a crazy week so lets get started.... It started bad last Monday. So some back story, I started this build with the thought in mind that a friend of mine had a "recently rebuilt FE C6" he was sending me. So I was super excited when I got it in.... But this is what I got.
I think this picture speaks for its self why it wont work
Anyways, got a care package from Denis Carpenter, so I started the heater rebuild.
And I also got my flex plate from summit 2 days ago.
Almost finished the dumb Clutch/Break conversion.
The fun stuff will start by the end of this week when I get my NEW transmission. I hope im about 2 weeks out on this project.
Project Page:
Project Page:
- MattHillFord
Quick Update 5/30/2012
Picked up Transmission!
Project Page:
Project Page:
