Best Way to get a little lift on 68 f100 4x4
So i just got a 68 f100 4x4 and am planning what i want to do with it first. Right now the tires on it are are 32-33 inches( cant remember). These really fill up the wheel wells. I would like to lift the truck maybe 2-3 inches just for extra room and for looks. I was thinking a body lift but id rather lift the whole truck(suspension lift). Has anyone added leaves to the rear springs? Because i really dont want to put lift blocks on the rear. As far as the front end how do i have to get taller coils or are there spacers available? Sorry ive done quite a bit of reading on here but didnt really find an answer yet, im kind of new to these years of trucks. Thanks, Will.
- rltvader
Re: Best Way to get a little lift on 68 f100 4x4
Please don't get a bodylift, they just aren't right.
As for the small lift, we put 2 inch aluminum blocks on my friend's suspension springs on his yukon and it rides smoother and is taller. I would get blocks for now, they are cheaper and give you an idea of what the truck will look like with a real suspension lit. Its your call, but there's a start.
-Built Ford Tough for a Reason
1969 F100 Red/White LWB (302)
1972 F250 Camper Special Ranger White LWB (FE)
- fomocoguy
Skyjacker makes 4" lift kits for your truck for under $500. http://www.skyjacker.com/
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- mybros71
Skyjacker products are great and I agree that a body lift of more than 2 inches is not so good. Remember though that the under 500 kit does not include shocks, brake hoses, or any provisions to correct the caster and track bar issues you are going to create when you install the kit. Make sure to read the instructions published on line before you pull the pin and buy.
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
