hello. so i have a 71 f250. camper special. i had a 390 in it. i just got it rebuilt, and im starting to put it back together. i was wondering if there was any certain way or procedures i have to do. i already put my heads on, the pushrods and the rocker assembly, also the intake manifold. i have torqued everything down thus far. any advice would be greatly appreciated.
i will keep posted on my progression as much as i can.
Rebuilt 390
Rebuilt 390
1971 f250 390 camper special
" Only two things are infinite, the universe and human stupidity, and im not sure about the former. " - Albert Einstein
" There are two ways to live: you can live as if nothing is a miracle; you can live as if everything is a miracle. " -
Albert Einstein
Albert Einstein
- 71PA_Highboy
Re: Rebuilt 390
As long as you don't forget the valley pan and the oil drainbacks from the valve train you are probably OK.. the rest is the same an a smallblock...
Good luck.
Good luck.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
Re: Rebuilt 390
71PA_Highboy wrote:As long as you don't forget the valley pan and the oil drainbacks from the valve train you are probably OK.. the rest is the same an a smallblock...
Good luck.
i have no idea what those things are. my first time putting an engine back together. can you explain please?
Albert Einstein
Albert Einstein
- 67mann
Re: Rebuilt 390
This isn't the best pic,but there the thin metal pcs in the white box in the bed of my truck.....if you have these parts..you'll reconize them by there shape
the two skinny pcs go under your rocker shafts and your vally pan(should already be in..based on what you've done)underneith intake
Re: Rebuilt 390
67mann wrote:This isn't the best pic,but there the thin metal pcs in the white box in the bed of my truck.....if you have these parts..you'll reconize them by there shape
[ Image ]
oh yes those are both in. i have everything ready to drop in. im having a really hard time lining up my transmission and engine. any tips?
Albert Einstein
Albert Einstein
