My GRABBER BLUE 72!
grabberblue72
Re: My GRABBER BLUE 72!
Post by grabberblue72 »
i got the other cab corner done. it fit way better then the passenger side.
Manny
Post by Manny »
Nice like the inner patch being flat like that since nobody makes panels for the inside that rots out. I like it. What gauge metal did you use for the inner patch on that so i can follow suit..... Or i'll give ya ten bucks to come do mine for me :lol: Looking good Nice deal on the welder too!! :thup:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
grabberblue72
I have been cutting metal off an old bump side hood. I'm not sure what other guys are doin for the inner corner, but a flat piece of metal, works great! Super easy to. The easiest way to do it is cut a square piece, weld it on, and after you get the outer skin on, just trim the inner to fit the curves of the outer skin. The picture above shows the square patch behind the outer skin.
Manny
Post by Manny »
Cool recycling at it's best. Love it looks clean, and probably gonna follow your steps right there when i go to do my inner cab corners. The ridges are facctory but hard to duplicate. One final question does the flat metal appear to have good rigidity or would it need to have some beads rolled into it to add some strength. :?
grabberblue72
i was concerned about that to, but once i got the corner skin welded on, it is solid. i got some crusher liner backing compound from work that i am thinking about filling the cab corners with. it is a glue type stuff that we pour in the gaps between the crusher liner and the mantel, to help dampn crushing vibration, and stop moister from getting in between the liner and mantel. i is a 2 part epoxy that will adhere to the metal and harden. if i do decide to use it in my cab corners, it will completly fill the cab corner, and hopefully dampen road noises significantly. and because it adheres so good, i will never have to worry about rust on the inside of the corners. it will also make them very solid .the only threat from rust would be from the out side, which i plan to coat with spray on box liner, along with the entire under side of the cab.
Manny
Post by Manny »
Cool stuff sounds like out have got it figured out how to make it work look forward to seeing more.
grabberblue72
Re: My GRABBER BLUE 72 2wd to 4wd build
my project has hit a major turning point. i just purchased a 1977 f150 short box 4x4. my grabber blue 72 is now going to be a 4x4! :o
grabberblue72
a little update!
cut the floors out, fixed the rocker panels, and welded the new floors and cab mounts in.
now i am working on fixing the floor suports and rockers.
F100builder
Post by F100builder »
Awesome, awesome, awesome! I am soooooo chomping at the bit to get back to work on my toys! Just one thing though...if it were me, and it's not, I would keep it a 2WD and have a hot rod truck since your '97 is already 4WD. I have a 2WD '69 and a 4WD '95 Xcab...similar trucks! Anyway, keep up the good work! :thup:
Patrick
grabberblue72
i got my 4wd frame back from the body shop. the frame ended up being alot mor bent and twisted then i was hoping for, but 25 hours on the frame rack and its back straight. :doh:
but on a good note, my new rims also showed up!Image
they are fuel 18x12 chrome hostage wheels. with a -44 offset.
i also am done all the welding on the cab and doors, im just waiting on my por15 paint to arrive, so i can coat the frame,and cab floor.
grabberblue72
Underside of cab and frame coated in por 15. Transfer case and tranny in. Still waiting on my motor mounts to show up.
I set the cab on the frame, hung a fender and threw a rim on to see how the rims are gunna fit. :love:
grabberblue72
My motor mounts from L&L products finally showed up today.
Only took 6 weeks.
The 460 fit perfect!
grabberblue72
got thew cab painted today!
FormerMarine1981
Post by FormerMarine1981 »
Looks great, should have it done any day now.
grabberblue72
heres a couple pics of the truck going to storage. truck is in a storage, until i get the garage at my new house ready to move in.
