Axel Help
lpatterson152658
Axel Help
Post by lpatterson152658 »
Ok I am having trouble finding a set or rear axles for my 68 F100 project. The rear end I pulled from the truck was 28 spine single traction, the housing I was told came from a 66 model. I got a god deal on a posi chunk that’s a 31 spine. My question is would I need to order a set of custom axels or is there anything from the junk yard I might check? I was thinking they would be a common axel but after a visit to summit and a few other parts stores am beginning to think otherwise. I have attached a copy of the info I put on a Moser order sheet. Any help would be appreciated.
lpatterson152658
Re: Axel Help
Here is a better look at the numbers
70_F100
Re: Axel Help
Post by 70_F100 »
If you're VERY lucky, you might find some 31-spline axles in some of the later (71-72) bumps. Needle-in-a-haystack kind of thing. :doh:
Best solution, IMHO, is to find a 73-79 housing with 31-spline axles. :thup:
The housing is 4" wider, which will put your rear wheels in line with the front (2" extra on each side). :hmm:
All you'll have to do to make it work is relocate the spring mounts, which will cost a LOT less than having custom axles made. :D
