Resurrecting "The Rangersuarus" My 69 Ranger
Mancar1
Re: Resurrecting "The Rangersuarus" My 69 Ranger
Post by Mancar1 »
I am enjoying your progress.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
69rangerf100
Post by 69rangerf100 »
dropped the 390 block off at the machine shop to be cleaned and new cam bearings installed. my painless wiring harness came in today and picked up a new sand blaster since my other one bit the dust
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
69rangerf100
so its been a while since i updated got the block back from the maching shop it had to go 30 over due to some scaring on 3 cylinder walls. repainted the block and installed the camshaft, crank, pistons and the arp head studs
David
69rangerf100
well its sad that is has been 9 months since i have updated this thread. since the last update the frame has been moved outside and i have been working on the body work on the cab. still working to get the undercoating off of it almost finished then i really start working stripping the paint off
David
69rangerf100
was finally able to do some work on the cab and got the top of the cab and the cowl sander down to bare medal. down side is that i found rust right above the drain rails above the doors not happy about that. any one got any ideas on what i should do to fill the holes. should i weld them up or use some type of patch putty hardener.
David
