Rear End Ratio Identification
Can anyone help me with identify what gear ratio I have in my 1972 F250 Crewcab? There is no tag on the rear end and all I found on the gears inside is the following 3 24 75 32503 A3E56 46-18
- 69FLATBED
Re: Rear End Ratio Identification
There is a way you can count the revolutions of the tires and divide them into the pinion revolutions or vise-versa... It's been so long since i've done it i cant remember. I used to have a dentside 4x4 with a odd 3.50 ratio and could never find the ratio's in my mudding days. I'm sure someone can lead you in the right direction.
Troy
_________________________
2000 F350 4x4 Crew Cab PSD
1969 F350 Flatbed 360 4spd DRW
!968 F250 4x4 Crew Cab SWB
Love my diesels hope to be gasoline free soon!
I had the same problem on mine when I bought it. I jacked the rear up, took off the left wheel. I marked the driveline and the drum so the marks were lined up with each other. I turned the drum and counted the rotation. For 1 rotation of the drum I had close to 3.5 turns of the driveline. Another way is a lot of work. take the diff out and count the teeth on the pinion and ring gear and divide one number into the other. I don't remeber which but, the end result will give you 3.00, 3.27, 3.50.
- PhantomoftheBumpside
IF the rear end is original, then the info should be on your Warranty Tag (VIN) on the door...
Find the code at the end of the 2nd line on your tag and check it against the decoder page http://www.fordification.com/tech/VIN72.htm
-- ROB --
The collective money pit details...
-On The Road-
1990 * 1FTEE14YZLHA83xxx ..- 138 E142 __ E 18 __ 3P
-Projects-
-Spares-
-Recently Departed-
1997 - 4M2DU55P9VUJ46xxx...- 112 4 22 _ _ 8 D4 U 1F
1997 - Dodge Caravan
1987 - Toyota Tercel Wagon FWD
1978 - Winnebago Brave (Dodge D800FC)
1970 - F10YRJ80xxx ..............- 131 3 F100 D _4 G 02
1968 - F25YRC99xxx .............- 131 E F253 B 81 G C8
1968 - F25YRD69xxx .............- 131 C F254 E 81 A 24
-On The Road-
-Projects-
-Spares-
-Recently Departed-
- michael69
Seen you have it opened up. Count number of teeth on pinion and the number of teeth on the ring gear. Then divide ring gear count by pinion count. That will give you the ratio.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
If you have open diff, just jack up one side, mark the tire and driveline at the bottom, turn tire 1 revolution and watch how many time the driveline turned, limited slip diff, lift both tires but no need to pull tires, drums and wheels turn at the same rate.
67 F-250 CUSTOM, 428, 4 SPEED, DISC BRAKES, P/S, EATON ELOCKER, 3.54 GEARS
68 F-250 CAMPER SPECIAL 360, C-6
