Thanks for info.70_F100 wrote:Plenty of them around here, but I don't know about VA.
Will the wheel fit? Lots of discussion here: http://www.fordification.com/tech/tilt.htm
Wanted - 390 parts and 67 F100 parts needed
Re: Wanted - 390 Flex Plate and radiator
Also needed is 390 starter bolts
I also need the plastic gear selector window thats on the 70-72 automatic steering columns.
1976 C6 automatic 2wd dust cover
67-69 chrome headlight doors
seatbelts for 67F100 drivers, passenger, and middle person belt. What colors do you have in a matching set?
- 67mann
Not sure that it's yr specific,but ya might wanna ask this guy....davbell22602 wrote:I also need the plastic gear selector window thats on the 70-72 automatic steering columns.
http://www.fordification.com/forum/view ... 11&t=63696
Looking for a backup 4bbl 390 intake that has the filler tube like one a 64 tbird thats not pitted where the gasket surface is. Also need the 390 coil bracket that mounts on intake.
Still need
blue seatbeats
C6 dust cover
radiator support for 390
390 radiator for automatic
67 sun visors
390 flexplate
driveshaft for a auto c6 2wd w/8ft on a 1/2 ton
window weatherstripping
door weatherstripping
shift indicator window
390 engine motor mount hardware
390 dizzy hold down clamp
390 radiator fan shroud
crossmember for automatic C6
67 headlight doors aluminum/chrome ones
heater control valve
horn relay
horn(s)
horn wiring harness
67 door jam (2)
67 lighter
67 cargo switch
blue seatbeats
C6 dust cover
67 sun visors
390 flexplate
horn relay
horn(s)
horn wiring harness
67 door jam (2)
67 lighter
67 cargo switch
Re: Wanted - 390 parts and 67 F100 parts needed
Still need these parts
Still need parts
I have some of the parts your looking for. Check out my parts on ebay ,I will be adding more every few days. I do have the 390 flex plate ,starter and misc items also ,I just haven't got to em yet, when I do they will be listed....Thanks, Rich.....http://www.ebay.com/sch/yourpartsdude/m ... 4340.l2562
Still needdavbell22602 wrote:Still need
blue seatbeats
C6 dust cover
67 sun visors
390 flexplate
horn relay
horn(s)
horn wiring harness
67 door jam (2)
67 lighter
67 cargo switch
Still looking for parts.
Dave ,I have some of the parts your looking for , they are on ebay .http://www.ebay.com/sch/yourpartsdude/m ... 4340.l2562
I also have the cross-member ,drive shaft and the steel rock guard for the aux gas tank. As far as hardware goes ,I sell all the nuts ,bolts and small parts from the truck combined in a USPS flat rate box for $25 shipped. Im almost done with the 68 Ranger, next inline are a 75 Elcamino with a 350 automatic and a 72 F100 with a 390 automatic.
Still need
67 spare tire carrier with hardware
blue seatbeats
67 sun visors
390 flexplate
horn relay
horn(s)
horn wiring harness
67 door jam (2)
67 wiring harness no cargo switch
brake warning light switch
cargo switch delete panel
doom light/door jam wiring harness
blue seatbeats
67 sun visors
390 flexplate
horn relay
horn(s)
horn wiring harness
67 door jam (2)
