c6 kickdown ?
evolutioneng
c6 kickdown ?
Post by evolutioneng »
i believe i have a c6. i will verify in a couple days. does anyone have pictures of how the kickdown in mounted.
Donnie
Re: c6 kickdown ?
Post by Donnie »
If you're not sure that it is a C6....C6 has 17 pan bolts & the bell housing & trans case is 1 piece
A C4 is 2 pieces...the bell unbolts from the case & the pan has 11 bolts.
Which end of the rod are you requesting info on, carb or trans?...........Donnie
evolutioneng
Re: c6 kickdown ?
woosh im glad i have a c6 than. i brother was assuming we had a c4 and im like that is very unlikley. both.i had a double pumper on the motor and every time i would switch it to drive it would want to stall out.no power.i know i did not have the carb tuned right and also i know the timing is off.i need to get someone that knows what they are doing to help me out.
