71 F100 lwb to swb and CV swap-update 10/30/11
harrysnyder
Re: 71 F100 longbed to shortbed and crown vic/explorer swap
Post by harrysnyder »
out with the old
I build driveshafts.
www.carolinadriveline.com
71 F100, 302, C4, 8.8, crown vic swap
68 F250, 360, NP435, Dana 24, Dana 60's f&r
harrysnyder
the frame
harrysnyder
another shot
harrysnyder
the remainders
FoPAR
Post by FoPAR »
the right tools always make the job so much easier. And a forklift is always a good thing to have around. Looks like your having fun need any help :D
"FoPar" because I love Fords and Mopars so just call me FoPar... :D
harrysnyder
yes it does help having access to the right tools. i'm hoping to have it sitting on the CV subframe and new rear end before august.
JG F100
Post by JG F100 »
good luck with the build, sounds like your doing what I did to mine. I wish I had a fork lift or lift for that matter. But it does look like blood was splattered all over it, lol.
harrysnyder
yeah i've followed your build closely and i love the way your truck turned out. i'm actually going to be using a crown vic rear end now because I bought an entire police interceptor shell.
harrysnyder
Re: 71 F100 longbed to shortbed and crown vic subframe and rear
haven't done any updating because I haven't done any work. so here are some pics.
I bought an ex-cop car for $450:
then I started removing pieces:
IFS on the ground. I just torched the frame that the subframe bolted to and dropped it all with one cut:
then I started on the rear:
harrysnyder
the front and rear on the ground:
the frame braced up and cutting the old crossmember out:
again:
sitting in there:
again:
again:
harrysnyder
machining the sleeves that the bolts run through between the frame:
sleeves:
sleeves 2:
sleeves 3, but you can also see the machined steel spacers that I used. each one is a different thickness, machined seperately to make that mount sit level despite the frames contour:
another shot:
harrysnyder
side shot, rear frame rails on jackstands:
rear axle with all the brackets plasma'd off:
frame boxed:
and as it sits now:
harrysnyder
project is gonna be on hold. gonna wok on my 68 highboy and get it up to daily driver status.
hazelnut
Re: 71 F100 lwb to swb and CV swap-update 10/30/11
Post by hazelnut »
Thats the cleanest install ive seen. i think you could sell a kit with the pipe and bushing to others wanting to do a swap.
harrysnyder
thanks man, it feels good to hear that! lots of work, lots of head-scratching.
