Fordomatic valve body issues
mlangbauer
Post by mlangbauer »
All, has anyone ever experienced the external transmission linkage "falling out" of the internal valve body "rod"? I ask because a couple of weeks ago it happened. I had it fixed and it has done it again. I pulled the trans pan today and the rod in the valve body and the external linkage aren't together any more (if that makes sense). I am wondering if possibly the external linkage piece that connects in the rod has a broken tip off. Seems strange this has happened twice.
Any ideas at all?
Thanks
Matt Langbauer
Denver, CO
1967 F250, Camper Special
Donnie
Re: Fordomatic valve body issues
Post by Donnie »
What year & what TRANS are you working on.? You say that it is coming apart inside the pan?
Can you show us a photo?........
Donnie
Post by Donnie »
The Ford o matic was a 2 speed not used in a long time... Just tell us the year, engine size,& model vehicle that you are working on....No photo is needed...Supply as much info as you can & someone will help you.........Donnie :?
BobbyFord
Post by BobbyFord »
Donnie, I think he means cruise-o-matic
ezernut9mm
Post by ezernut9mm »
probably an mx.
mlangbauer
My apologies, you are absolutely right. I was thinking cruise-o-matic and wrote ford. The transmission is in my 67 F250. For some reason this is the 2nd time the transmission linkage has become fallen out of the valve body "rod". I was able to get it in and it works now. From what I can see everything seems to be correct as far as the mechanisms. Just not sure if anyone else has ever experienced this.
Matt Langbauer
Denver, CO
Donnie
Post by Donnie »
I thought that perhaps you had a classic 62 Falcon Wagen that you were working on. :lol: Donnie
