what oil to use in my rear end?
sharkdog
Post by sharkdog »
just wondering what oil I should use in my rear end my owners manual which is obviously 40 years old says use ford hypiod gear lubricant. Just wondering what that translates 2 in modern times. and if I have a stock 1970 f-100 with a 360-c6 2wd do you think it has a lsd in it/ how could I tell.
Thanks Pete
1970 f-100 360 c-6 2wd ps/pb longbox
67mann
Re: what oil to use in my rear end?
Post by 67mann »
forrestbump wrote:
depthcharge711 wrote:What fluid and how much needs to go into that badboy?
Fluid Type: 80wt or 90wt gear oil
Volume: 2-1/2 to 3 quarts approximately
Add friction modifer IF equipped with Trac-Lok, BUT NOT required IF Detroit Locker.
Racer Z
Post by Racer Z »
90 weight Hypoid gear oil. You can buy it at any auto parts store. Some of the new stuff is synthetic and won't mix with the real oil based stuff, so pay attention to what you get.
There are several ways to test for an LSD (limited slip differential). The best way is to remove the inspection cover and look for a clutch. If you find an LSD unit, then you will still need Hypoid gear oil, but read the fine print on the bottle, it will say that it is suitable for an LSD, or not. If it does not mention LSD, put it back.
If you use a non-LSD oil in an LSD unit, you risk burning out up the clutches. With burned clutches it will function like a standard open diffy. Some will chatter in the turn, others will not.
Nitekruizer
Post by Nitekruizer »
Lift both rear wheels off the ground. Try turning one wheel by hand.If the other wheel turns in the same direction it's Limited Slip. If the other wheel turns in the opposite direction it's not.
Racer Z
Post by Racer Z »
Nitekruizer wrote:Lift both rear wheels off the ground. Try turning one wheel by hand.If the other wheel turns in the same direction it's Limited Slip. If the other wheel turns in the opposite direction it's not.
That only works on certain types of LSD units. Because of the different types, the best way is to remove the inspection cover and look for a clutch pack. If it is an LSD, it will be obvious at this point.
STROKER69
Post by STROKER69 »
Racer Z
His truck being a 1970 F100 wouldn't that be a 9" rear and no inspection cover. I would use the old S.T.O.P. method.
That is to stomp on pedal from a stand still on pavement and see if you get only one or two black lines behind you, but be careful you might see blue lights also :(
Racer Z
Post by Racer Z »
STROKER69 wrote:Racer Z
Hmm. That makes it hard to take a quick peek inside.
69f-100
Post by 69f-100 »
it should, mine is a 69 and it has a 9" in it..
tnlprt
Post by tnlprt »
Do me a favor and post a picture of the removable cover on your 9 inch
If it is the factory rear the only plug is the fill plug in the carrier
71fordkid
Post by 71fordkid »
I used motorcraft 75-140 full synth in my 9'' with a spool.
Ex Ford diesel dealership senior master tech (6 years)
Current bmw level 4 tech.
1972 Ford F100 Stepside - 302, forged TRW flat tops, performer 289 intake, edelbrock 600 cfm carb, CV IFS swap, 4.10 LSD disc 8.8 , AOD 4 speed auto. Currently 5 years in the making.
