budget build
budget build
Ok I am picking up a fresh 302 marine engine tomorrow this winter I am gonna build it with aluminum heads and a cam any ideas I want to pull 450 hp any ideas would be helpful think Im gonna try the pro-comp heads but what cam should I use? help!!!
love my hot rod ford
Re: budget build
just got my new marine ford 302 motor home now to strip those little heads and intake off
Re: budget build
careful. the marine engines can be different than the regular car or truck engines. do a search for as guy with the member name layedout. it maybe spelled slightly different thn that. he used a marine engine too. other gave him some info on the marine enge and wht could be different about it. such as reverse rotation.
Re: budget build
thanks i found out about reverse rotation last night I am going to call the company who built it and have them look up the serial number they stamped on it I just want the short block everything else is coming off and will be changed but thanks for the heads up I will look him up and ask him
