What headers will work
Doug Comer
Re: What headers will work
Post by Doug Comer »
From my knowledge most companies that make them and say they fit, they will. If you had a stock hiegth and high pinion then most won't. I had to run block huggers on mine.
Doug
1967 f100 4x4
1970 f250 4x4
CrypticRacer13
Post by CrypticRacer13 »
Dougs right here, all of those should fit your needs seeing how your still running the low pinion axle up front. My highboy has a 78' High pinion an my hooker headers are beat to hell from the pinion smaking the driver side in the past.
-Mike-
ECV 1849
1971ford
Post by 1971ford »
ahh. Good to know.
But I do plan on putting a high pinion up front in the future... now which set of headers? :D
I'm lifted 3ish inches, but Mike says his headers are beat and he is lifted the same. Hmmmm
CrypticRacer13
You can't go wrong with either set you have picked out, in my small block mopar days I've ran both brands, I'm partial to hookers cuz I I own a set of 2" primary fenderwells for my 440 in the dart an there amazing an made jobs of power lol an they ain't nothing wrong with a Hooker if your just driving around looking lolw :thup:
-Mike-
ECV 1849
fireguywtc
Post by fireguywtc »
I have those hooker headers on mine and they fit well, but are close to the starter by about 1/2 inch. So buy wrap if you get them. I like them because they have the thickest metal on the tube and thick and heavy flanges. They also don't have the motor mount going through the middle of them like some headers do. The bad is they don't have the exhaust flanges on the collectors so I had to have them welded on, no big deal to me.
Bill
Doug Comer
Sanderson block huggers will fit either way you go.
Doug
1967 f100 4x4
1970 f250 4x4
