Today I received my new ring&pinion for my low pinion 44 and the gear angle is reversed from the old one,did I screw up and order the wrong one??
the old one is the same as the rear yet the new one was labeled for a 44 front,what have I done wrong/ Should I have ordered a standard rotation set?
If pics will help clarify I will take one.
Dana 44 front ring & pinion ?
- eggman918
Re: Dana 44 front ring & pinion ?
The cut should be the same as the old one. The new gears should be labeled high pinion or low pinion (low pinion being correct for your app.)
- eggman918
Thanks again Dustin,the closer I get to finishing this project the more I wonder if I ever will...one more thing off the list
Steve.
Steve.
