ford 3 speed
- blumule
ford 3 speed
Have beem given a ford 3 speed toploader with the side tag reading rat-g2 on side. Would this be ok behind a 390? Also what is this transmission called when ordering seals and gaskets? Nobody seems to understand just a ford truck 3 speed. is there another name for it?
Re: ford 3 speed
idk. email these guys. http://www.davidkeetoploaders.com/3speedidchart.htm
- Fo-Mo-Co
Re: ford 3 speed
It should hold up with the correct input shaft. It's the Ford 3.03
"We don't want tradition. We want to live in the present and the only history that is worth a tinker's dam is the history we make today."
Henry Ford
Henry Ford
- blumule
Re: ford 3 speed
that makes me more comfortable swapping this one for the one thats in there. I havent been able to do a full comparison yet but i have noticed this one in question doesnt have a bottom drain plug.what would this be? maybe an earlier year?
Re: ford 3 speed
Had one bolted up to my 302. Been a great transmission. No drain plug on bottom, only on the side.
- Fo-Mo-Co
Re: ford 3 speed
My toploader is the same way. You van pull the bolt at the bottom of the tail shaft housing and it will drain. They are a tough trans. From what I understand they are as tough as a toploader. They maybe the same just missing 4th. It was put into some of the 2wd fe trucks from the factory.
Henry Ford
Henry Ford
- blumule
Re: ford 3 speed
it is same trans as 4 speed. just curious as to why they had different tag numbers for the different motors. either way i think i should be good.
- Fo-Mo-Co
Re: ford 3 speed
I think they had different input and output shafts depending on the motor. Not sure about that. They also had a close and wide ratio in the 4 speed. Don't know if the 3 speed was the same or not.blumule wrote:it is same trans as 4 speed. just curious as to why they had different tag numbers for the different motors. either way i think i should be good.
Henry Ford
Henry Ford
- papabug71
Re: ford 3 speed
Ford put the 303 behind 360's & 390's from the factory. You would really have to work at it to tear up a 3 speed. & I swear a member here or over at .net put one behind a 460 using a bell housing from a NP435, but I cant find the post.
Believe it or not, they're hard to find in my area. I have 2 spairs, just in case!
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
