Hey guys, my question of the day is how hard would it be to bolt in a 67-72 ( im assuming. maybe later years work too.) dually read end into the rear end of my 72 2wd f250? Are they bolt in? driveline hookup and spring compatibility is my real concern. I can plumb brake lines and I have fender flares off some of my old buses that would hug the bed wonderfully. Thanks for any input you all may have!
Rich
installing a f350 rear end.
- 1972hiboy
Rich
Dont eat yellow snow.....
Re: installing a f350 rear end.
Since there were no F-350 DRW pickups made in these years there were only cab chassis dual trucks. Cab chassis trucks have the same rear wms width as a standard pickup. The Dana 70's used under 67-72 F-350 cab chassis trucks are 23 spline and not a worthwhile rear axle to swap with, they are not supported for parts, gears, axles, etc. and it's iffy if there's any strength advantage over a Dana 60. If you swap it in the driveline will need to be about 3/4" shorter and none of the spring hardware from the 60 will fit, you'll need the Dana 70 stuff for the larger axle tubes.
You might as well put duals on your stock rear end. Might run into the wheelwell depending on tire/wheel size though.
hello dustin, I dont want to hijack this thread but im in need of your expertise and I wanted to ask you a question about my cummins swap Im getting ready to start. should I pm you??
1972 crew highboy project
1972 crew highboy 12v cummins daily driver
1970 f250 2wd ranger xlt camper special (first car)
1970 f100 lwb 2wd driver quality
1976 highboy driver quality
etc, etc, etc........
- 1972hiboy
Hey Dustin thank you for your input and thanks for pointing me in the right direction for new u-bolts for my other truck. Is it really just as easy as bolting duel wheel to my stock rear end? I didnt even think about checking if the lug studs where long enough. Im not looking for huge tires just a little stability for some of the heavier loads.
Rich
