71 F100 lwb to swb and CV swap-update 10/30/11
- harrysnyder
Re: 71 F100 longbed to shortbed and crown vic/explorer swap
out with the old
I build driveshafts.
www.carolinadriveline.com
71 F100, 302, C4, 8.8, crown vic swap
68 F250, 360, NP435, Dana 24, Dana 60's f&r
- harrysnyder
the frame
- harrysnyder
another shot
- harrysnyder
the remainders
- FoPAR
the right tools always make the job so much easier. And a forklift is always a good thing to have around. Looks like your having fun need any help
"FoPar" because I love Fords and Mopars so just call me FoPar...
- harrysnyder
yes it does help having access to the right tools. i'm hoping to have it sitting on the CV subframe and new rear end before august.
- JG F100
good luck with the build, sounds like your doing what I did to mine. I wish I had a fork lift or lift for that matter. But it does look like blood was splattered all over it, .
- harrysnyder
yeah i've followed your build closely and i love the way your truck turned out. i'm actually going to be using a crown vic rear end now because I bought an entire police interceptor shell.
- harrysnyder
Re: 71 F100 longbed to shortbed and crown vic subframe and rear
haven't done any updating because I haven't done any work. so here are some pics.
I bought an ex-cop car for $450:
then I started removing pieces:
IFS on the ground. I just torched the frame that the subframe bolted to and dropped it all with one cut:
then I started on the rear:
- harrysnyder
the front and rear on the ground:
the frame braced up and cutting the old crossmember out:
again:
sitting in there:
again:
again:
again:
sitting in there:
again:
again:
- harrysnyder
machining the sleeves that the bolts run through between the frame:
sleeves:
sleeves 2:
sleeves 3, but you can also see the machined steel spacers that I used. each one is a different thickness, machined seperately to make that mount sit level despite the frames contour:
another shot:
sleeves:
sleeves 2:
another shot:
- harrysnyder
side shot, rear frame rails on jackstands:
rear axle with all the brackets plasma'd off:
frame boxed:
and as it sits now:
frame boxed:
and as it sits now:
- harrysnyder
project is gonna be on hold. gonna wok on my 68 highboy and get it up to daily driver status.
Re: 71 F100 lwb to swb and CV swap-update 10/30/11
Thats the cleanest install ive seen. i think you could sell a kit with the pipe and bushing to others wanting to do a swap.
- harrysnyder
thanks man, it feels good to hear that! lots of work, lots of head-scratching.
