ford 3 speed
blumule
ford 3 speed
Post by blumule »
Have beem given a ford 3 speed toploader with the side tag reading rat-g2 on side. Would this be ok behind a 390? Also what is this transmission called when ordering seals and gaskets? Nobody seems to understand just a ford truck 3 speed. is there another name for it?
Re: ford 3 speed
Fo-Mo-Co
Re: ford 3 speed
Post by Fo-Mo-Co »
It should hold up with the correct input shaft. It's the Ford 3.03
"We don't want tradition. We want to live in the present and the only history that is worth a tinker's dam is the history we make today."
Henry Ford
blumule
Re: ford 3 speed
Post by blumule »
that makes me more comfortable swapping this one for the one thats in there. I havent been able to do a full comparison yet but i have noticed this one in question doesnt have a bottom drain plug.what would this be? maybe an earlier year?
Re: ford 3 speed
Had one bolted up to my 302. Been a great transmission. No drain plug on bottom, only on the side.
Fo-Mo-Co
Re: ford 3 speed
Post by Fo-Mo-Co »
My toploader is the same way. You van pull the bolt at the bottom of the tail shaft housing and it will drain. They are a tough trans. From what I understand they are as tough as a toploader. They maybe the same just missing 4th. It was put into some of the 2wd fe trucks from the factory.
Henry Ford
blumule
Re: ford 3 speed
Post by blumule »
it is same trans as 4 speed. just curious as to why they had different tag numbers for the different motors. either way i think i should be good.
Fo-Mo-Co
Re: ford 3 speed
Post by Fo-Mo-Co »
blumule wrote:it is same trans as 4 speed. just curious as to why they had different tag numbers for the different motors. either way i think i should be good.
I think they had different input and output shafts depending on the motor. Not sure about that. They also had a close and wide ratio in the 4 speed. Don't know if the 3 speed was the same or not.
Henry Ford
papabug71
Re: ford 3 speed
Post by papabug71 »
Ford put the 303 behind 360's & 390's from the factory. You would really have to work at it to tear up a 3 speed. & I swear a member here or over at .net put one behind a 460 using a bell housing from a NP435, but I cant find the post.
Believe it or not, they're hard to find in my area. I have 2 spairs, just in case!
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
