Another speedometer problem
timmytim
Post by timmytim »
Every since I've own my truck the speedometer needle has jumped around at speeds of 0-35. I finally got around to pulling cable out and inspecting it. I pulled the cable all the way out and cleaned cable and housing with brake cleaner. Then rubbed wheel bearing grease all down cable and installed it. Well it still jumps around.... To me the cable looked a tad short and maybe pulling away from the gear a low speeds. But I don't know....any ideas?
:fr:
buy'em dirty sale'em clean
get more money for the same
machine.....
:loco:
My 1967 bump: http://www.fordification.com/forum/view ... 09#p668209
My 1970 Bump: http://www.fordification.com/forum/view ... 16&t=50726
Re: Another speedometer problem
it may be the inside of the cable was dirty too. it may have needed cleaned also. i dont think being alsight bit too short would do anything to make it jump.
timmytim
Post by timmytim »
I sprayed brake cleaner down it but I may need to let it soak over night in some petro
:fr:
machine.....
:loco:
timmytim
Post by timmytim »
Craig what would be cool is if I could find somekind of steel brush to push through the cable housing.
:fr:
machine.....
:loco:
maybe a air gun. after you spray the cleaner through it and let it soak.
timmytim
Post by timmytim »
My air compressor was stolen many moons ago and I never replaced it
:fr:
machine.....
:loco:
timmytim
Post by timmytim »
Welp I called lmc and ended up buying a new cable and also a new gear. The gear I have is 19 tooth and speedometer is off 10 miles too fast. So I ordered a 21 tooth.
:fr:
machine.....
:loco:
for a c6 there are two lengths of gears. i hope you got the right one. i forget right now how to tell exactly. i'd have to do a search to remind myself what the difference was.
timmytim
Post by timmytim »
Crap Craig
:fr:
machine.....
:loco:
timmytim
Post by timmytim »
The new cable works good and new gear I bout made speed accurate. The cable is about a foot too long but it will do....
:fr:
machine.....
:loco:
