I usually avoid 4x4's like the plague but:
i checked out a 68 f250 4x4 the other day (really quick,it was p!$$'n rain and getting dark) has a 360 or 352 w/auto trans and either the trans or the engine ( can't remember which ) is toast,interior is in primo condition,cab mounts good ,rad support good,grille is A-1, boxand most of the sheetmetal is dent and rust free (except that the roof is rotten above the windshield) i'm trying to get it for $200 or less...so we'll see.
i'm trying to score it for parts,but i also have a tendency to feel pity on fallen soldiers & try to fix any bumps i come across
(and i have an NP435 and a 551 looking for a home) ..so do these trucks have divorced transfer cases? if i'm shoving a manual trans in place of an auto in this thang what other things would hafta be replaced (driveline wise)?
as always any and all help is greatly appreciated
68 f250 4x4 -divorced transfer case or what?
- fireguywtc
Re: 68 f250 4x4 -divorced transfer case or what?
afaik all F-250 4x4s came with a divorced transfer case. They all came with manual transmissions also so it was converted to an auto at some point. I doubt it was converted to married transfer case when it was converted to an auto. Its possible though I guess. I would guess it would be pretty east to convert it back to manual but would probably need a longer intermediate drive shaft between the trans and tranfer case.
Bill
- mlheppl
IIRC in 1968 there were 2 engines available, the 360 and the 300-I6. Of course a lot could have been converted in the last 43 years LOL. There is a difference in the 2wd and 4wd F250 NP435 transmissions. The tailshaft housing has the same bolt pattern, but the 4wd version has a place for mounting the transfer case shifter that the 2wd version does not. If you can get a F250 4wd 435 tail shaft housing it will bolt onto a 2wd 435 transmission provided it came with a divorced transfer case. The F100 435 transmissions with the mated transfer case has a different bolt pattern on the tailshaft housing than the 2wd or F250 4wd versions and this housing will not bolt onto the 2wd 435 tranny. HTH
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
71 F250 4X4
- fireguywtc
I recently did the swap since I had a good 2wd np 435, and a bum 4wd one. Here is a thread highlighting the swap of the parts necessary to convert one.
http://www.fordification.com/forum/view ... =4&t=55936
Bill
nice! thanx guys. The np435 i have is originally out of a mid 70's 2wd f250 camper special so the info's good to know for sure.
I'm calling the truck i'm lookin at a 68 because the grille is a 68,god only knows what year the truck actually is,couldn't get the doors open to check the tags cuz it was locked up
however - i'm pretty sure the truck IS a factory auto tranny truck & i've seen at least 4 of them before ( all 70-72 big block trucks ) while scrounging thru the crush pile @ the wrecker (10 yrs or more ago)...who knows maybe its a Canadian thing....kinda like the 69 f350 crewcab sporting a special order 428(!) didn't believe that until the original owner pulled out the paperwork..the block was cracked,but its still a shame he wouldn't part with it
anyways,thanx again and if anyone else has some more wisdom to impart its much appreciated as well
