leaking dana 44 closed knuckle
71highboy
Post by 71highboy »
hi all.i replace the seal and the felt wiper but it still seems to leak a bit from the lower kingpin cap any suggestions on what could cause this?thank you :fr: :help:it is on a 1971 f250. :fr: got it fixed
71PA_Highboy
Re: leaking dana 44 closed knuckle
Post by 71PA_Highboy »
There is a seal above the kingpin.
It is only hard to get to because you have to pull from the bottom.
Be careful if you choose to do it in the vehicle as the bearing will fall out ... make sure you don't frop it in the dirt or sand.
Good luck!
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
71highboy
Post by 71highboy »
ok thank you :fr:
