leaking dana 44 closed knuckle
hi all.i replace the seal and the felt wiper but it still seems to leak a bit from the lower kingpin cap any suggestions on what could cause this?thank you :help:it is on a 1971 f250. got it fixed
- 71PA_Highboy
Re: leaking dana 44 closed knuckle
There is a seal above the kingpin.
It is only hard to get to because you have to pull from the bottom.
Be careful if you choose to do it in the vehicle as the bearing will fall out ... make sure you don't frop it in the dirt or sand.
Good luck!
Good luck!
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
ok thank you
